hmmmnz's 1(50)cc un-cut down vespa
hmmmnz
ok ill post all in 1 big hit, and follow up in the next few weeks,
a mate borrowed it for a bit, and dinged up the old girl so she has had a panel beat and is away getting repainted by a pro.... not me and my rattle can glory,
as you can see, its had a pretty rough life and has been cut down,
a bit of a fad in the late 80's,
so thats the bad, the good is the engine has had extensive work done, porting, the the crank intake has been modified, and she runs pretty damn well breathing through the 200cc carb,
its also been fitted with a custom expansion chamber, and 10" wheels to give her a bit of clearance,
any way, the wee vespa will never be an original scoot again, so there is no point even trying to make it so,
but i will give her a complete strip down and try and give it a bit of normalcy again,
strip down, take 1
some one has cut of the side panel, so the engine is always exposed now
engine out (less than 30mins)
what they had to do to fit the larger engine in.
its to push the shock back wards so it doesnt hit the engine, ill come up with a better method
and front end off
all the cables out
and done!!
so thats stage 1
]stage 3,
primer down, and i think i have picked up most of the little chips and nicks etc, so should be good to lay down the first layer of colour tonight
heres the pics
as you can see the under side of the vespa is black,
ive used a hard wearing but flexible chassis paint that hopfully will do the job of protecting the exposed areas from chips etc, it dents but doesnt chip or flake
the rest is just filled and primed
paint is done....
dun dun dun
tomorrow ill put all the cabling in place, along with the wiring, ande hopefully fit the front end, and if all goes well ill pop the engine back in after i strip down the top end.
here is the almost finished result
yeah, i got it off matt, great guy, certainly knows his stuff
the exhaust was a bodge-together special,
so loud its obnoxious :D it does come on the pipe but not untill quite high up the rev range, doesnt help with the 10" wheels either,
in its former cut down life, it was by far and away the dodgiest 2 wheeled thing i have ever ridden, frame used to flex like you wouldnt believe, and the dampener is buggered so dives under braking :D
still pretty funny on the motorway cruising past cars,
Looks like the scootrs 10" wheels on 8" hubs, Matt swears by them. How's the braking?
They all dive under braking, it's the suspension design. Going around bumpy corners on a vespa is interesting when you get a bit of that sideways shuffle going on.
100km/h never felt as fast as it does on a vespa!
OT: James, u still want these radios? else I'm gonna chuck them or bang them on TM
edit : yeah matt chucked thos rims on, it would be nice to have that little extra torque of the smaller 8" wheels,
but with the massive expansion chamber it would scrape every where, plus 8" wheels never feel very stable
as for braking ..... well aided with your feet ... it stops :D you just have to plan ahead and use the gears
right bitches, its been a while since the vespa had any love,
just got back from my mate (the worlds slowest painter)
fmbwXC0n2fI
  • 6 months later...
