escort74
escort74's 1974 Ford Escort Mk1 - Project Alan Mann
156 posts in this topic
Struts back from silver paz and have been de-embrittled
Cant buy off the shelf du-bushes so had to machine the O.D of these
very tricky as it kept catching the split on the bush then self destroying.
Made a mandrel and had a hose clamp around the bush and took small cuts until I finally had 4 bushes.
Bushes in
bilstein shocks in , 300lb 2.25" 9" long springs
Next to make are top hats and get some hubs.
Also might need keeper springs to get nice and low
7 people like this
Share this post
Link to post
Setting up the top hat in the lathe
Machining time
Machining Complete
Bearing / circlip assembled
9 people like this
Share this post
Link to post
Machining some top nuts and a spacer for the struts
Ordered a pair of alloy hubs from peter Lloyd rallying
Pressing bearings in
Pressing studs in
almost time to fully assemble the struts
9 people like this
Share this post
Link to post
Trial fit of the Pinto engine
W50 gearbox test fit
made up a crossmember
8 people like this
Share this post
Link to post
Fixing the front fibreglass guards
Rivnuts
Got some work to do to fix my gaps
5 people like this
Share this post
Link to post
Wont be needing this anymore
bye bye trim holes
and finally bye bye ugly reverse lights
and no more automatic badge :D
5 people like this
Share this post
Link to post
Welding time
Chopped the original mounts off the crossmember
and added a gusset in.
6 people like this
Share this post
Link to post
Work bought a pallet load of machine parts from the UK
and I managed to sneek a few escort parts onboard
Window , door and boot seals
Electronic Dizzy kit
Adjustable pedal box
2 people like this
Share this post
Link to post
Quick Rack
Twin Cowel Dash
and full set of lexan windows
9 people like this
Share this post
Link to post
Had to convert passenger door to match
lock on the drivers side
riveted and
fibre glassed rear arches on
More holes
8 people like this
Share this post
Link to post
Engine back in
finally got the garage (sorry mum) , good to get the car inside to work on
9 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
