Goat
Seedy Al's Brown Crown
341 posts in this topic
i was about to mention said agreement. coon will be in the work bay in Jan
good to see you've bitten off a decnt chunk right in the nick of time Al! holla if i can do/make anything to help.
Share this post
Link to post
If its hard against the mount (but still fitting) then could you take/grind some off the mount then make the "flexi" a straight piece of pipe to remove the extra diameter of the concertina?
Share this post
Link to post
unfortunantly the part i would need to grind away would include some of the rubber so that is a no go. whish I could tho!!! As for the removal of the flexi, I assume its there to allow expansion of the manfilds as they are two piece etc, so although I did think that and still consider it an option, it may result in cracked exhasut pipe maybe?
Share this post
Link to post
Also sorry bout that ECU had no idea it wasn't in the box with the loom! fuck knows where it went then
Share this post
Link to post
Could you dent the flexi inwards a touch?
By dent do you mean hit it with a hammer until it fits sweet?
Share this post
Link to post
was considering heat haha
I dont mind cutting and welding, its fun.
well exhasuts anyway, not looking forward to recessing my fuel tank so much thou.... bet that cunt will fucken leak forever.
All good spence, got the perfect fitting motor for a sweet price so no complains here, just a mild set back :)
Share this post
Link to post
Hmmm.....think I have found my answer to the problem with trying to get wires to the fuel pump.
Something like this should work ok.
Time to ask mix master manu for a favour
Share this post
Link to post
How so??
Also those connections - are they designed to be inside a fuel tank? Just thinking about the connection sparking..
Share this post
Link to post
running external fuel pump on a carb tank, with no baffling, would cause fuel surge, although everyone says oh just keep your wgaon tank a third full or whatever, when your on an extended wagon trip, this is not ideal.
that was designed for a fuel tank yes.
Share this post
Link to post
haha, also you had me worried there for a tick, but as I will have both the connectors isolated from the tank, and atleast a few centermeters apart, I can see any spark issues happening, guess will see,
if I get shot down in a blaze of glory we will know why haha
Share this post
Link to post
I could, but I had this disscusstion with a few people. Not really keen to spend the money on such a system. Dont worry, I have a plan
As for lowering the tank, its already the lowest part of the car haha
And I like my cars LOW
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
