Goat
Seedy Al's Brown Crown
345 posts in this topic
I did do the rev test.
Anyway it would seem second ignitior has fixed the issue. Still worries me when I drive it but hopefully I will build some confidence in it. Motor sounds dreamy tho.
2 people like this
Share this post
Link to post
Yes when you have a run of problems that you are never sure if you have fixed them I get this nagging thought ok when is it going to die again
2 people like this
Share this post
Link to post
On 29/01/2017 at 20:38, k-trips said:
You aren't using a 6V coil by chance? It requires a ballast resistor if so.
The primary resistance in a 6V coil is 1.5ohms and a 12V is 3.0ohms (ballast resistors are normally 1.5ohms)
(I'm going from old memory so I could be wrong)
i bypassed the ballast on my wagon when i went to electronic ignition but didnt change the coil. hasnt blown up yet. I heard it would give a fatter spark at the expense of coil life
Share this post
Link to post
I know dem feels, have had two ignition failures for no identifiable reason. Current iteration invloves a custom piece of loom I can swap in quickly to get it running stock again
2 people like this
Share this post
Link to post
Seen this in action lol. Good back up plan!
1 person likes this
Share this post
Link to post
wot
Share this post
Link to post
I gained 1 psi.
so I guess thats something.
but not enough. there is something wrong internally. My guess would be the auxiliary shaft bearings, as these would pretty much be the only things I havn't replaced.
So the big question I have been internalizing is what to do.
I have a few options.
1) Just sell the car and be done with it.
2) Pull motor out, strip it down and have a dead car while I sort out what the fuck is going on
3) Pull motor and swap over parts to the Meu that was in there before this motor went in, and then strip down 5m and figure out whats going on at a later date.
4) Push it to thje back of the workshop and start collectiong parts to try mount the 1kz I have sitting around, which would be more money I have right now to sort, as I would need to buy an auto gearbox and some way to control it, as motor is running a manualised pump.
So yeah. Yay for shit cars.
At this point I am very much tossing up between option 1 and option 3.
Share this post
Link to post
If I do option 3, then motor swap is happening this weekend at work. My issue with that is, I was planning on doing the exhaust on my sedan. And not doing that this weekend pushes that whole build back 3 weeks.
Cars suck
Share this post
Link to post
What a ballache.
Share this post
Link to post
Groovey
Old motor in back in.
Now time to see if its actually any good, given it had only done about 60km of driving if that, last time it was in the car.
keep your cell phones on people!
5 people like this
Share this post
Link to post
Drove 5min to the second hand shop, bought a bloodhound gang cd. Then proceeded to drive 80km round trip through whitemans valley. Went well besides the fact the jets are a tad big given this motor is 2l verse the 2.8
So it will fucking do. Just need to swap over bench seat and should be gravey
8 people like this
Share this post
Link to post
Good job, Allan.
Share this post
Link to post
Mind five Al, good shit
Share this post
Link to post
Good shit man. Great that you're sticking with it. A toast and some hugs that Nats.
Share this post
Link to post
get some smiles per miles in to refuel the give a fuck meter. sucks having ball ache not going cars
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
