Seedy Al Posted January 24, 2017 Share Posted January 24, 2017 Hah actually yes 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 24, 2017 Share Posted January 24, 2017 I was hoping to have it running tonight. But either the battery that repco sold me isn't as charged as they said, or my starter motor is pooped. Either option is possible. Pretty sure I have a spare starter motor or 3 1 Quote Link to comment Share on other sites More sharing options...
Liam-B Posted January 24, 2017 Share Posted January 24, 2017 Had more engine swaps than most now haha. Is this one a keeper?! Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 24, 2017 Share Posted January 24, 2017 Yeah man. Rebuilt so hopefully reliable as an m motor can be, and converted to column shift auto and bench seat for max cruising. Wagons don't need to be fast. 4 Quote Link to comment Share on other sites More sharing options...
igor Posted January 24, 2017 Share Posted January 24, 2017 +1 for column shift and bench. Do you need a cert for changing from buckets to a bench? Quote Link to comment Share on other sites More sharing options...
Liam-B Posted January 24, 2017 Share Posted January 24, 2017 Bench seat and column sounds lush and pretty much the only way to roll in a wagon. 3 speed auto or 4? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 24, 2017 Share Posted January 24, 2017 Na every thing is straight bolt in so its all legit. Besides replacing the section of floor where the hand brake used to be. As it now has dash style mounted hand brake also. 3 speed with over drive. 1 Quote Link to comment Share on other sites More sharing options...
Liam-B Posted January 24, 2017 Share Posted January 24, 2017 Nobody would even know these days if the seats were supposed to be bench or not anyway. What VTNZ are you taking it to in welly? Are they easy going or a bit hard out these days on old cars? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 25, 2017 Share Posted January 25, 2017 Swap the battery I bought yesterday for one with 60 more cca and gave it a charge. Once I had built up oil pressure and plugged the coil back, this started straight away. Was a bit surprised. Still seems to have idle issues when warm. However I have not set timing or anything. Need to clean over flow bottle so I can jam that in and fit radiator cap. Then once its warm I can attempt another tune. The little manual I have is pretty good for setting these carbs up. Tho am a little worried that it might have a vac leak in the throttle spindle. We will see. 5 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted January 25, 2017 Share Posted January 25, 2017 Toyota carb lyfe Even when its running sweet its still not sweet 2 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 25, 2017 Share Posted January 25, 2017 Lol pretty much. Hopefully can get it close enough with out pulling it apart for a rebuild Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 26, 2017 Share Posted January 26, 2017 Well this evening was a bit of a fuck around. Had car running, set timing which was so close was lol. Running away getting warm and then suddenly it just dies. Wtf is this shit. No spark it would seem. Checked some stuff and swapped coil with no joy. Dissy I was using had one of those magic boxes in it. Would seem it failed. Luckly I had hoarded a factory electronic ignition system for this. So swapped every thing over and back to key starting like a boss. Still idles like a cunt. I neeeeed to buy a better throttle spring tomorrow and have a crack at tuning. Tho I do truly suspect rhe carb needs a rebuild. Should aliexpress one for lols. 2 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 29, 2017 Share Posted January 29, 2017 (edited) Derp Edited January 29, 2017 by Seedy Al I posted in a troll thread Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 29, 2017 Share Posted January 29, 2017 eugh. basic voltage tests done etc? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 29, 2017 Share Posted January 29, 2017 Yea. Coil power getting 12.7v. Cant think what else to check lol. Coil it self was replaced the first time it all had a mare. Quote Link to comment Share on other sites More sharing options...
tortron Posted January 29, 2017 Share Posted January 29, 2017 How many ohms is the coil Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 29, 2017 Share Posted January 29, 2017 No idea. Will check tomorrow. What you thinking? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 29, 2017 Share Posted January 29, 2017 You aren't using a 6V coil by chance? It requires a ballast resistor if so. The primary resistance in a 6V coil is 1.5ohms and a 12V is 3.0ohms (ballast resistors are normally 1.5ohms) (I'm going from old memory so I could be wrong) Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 29, 2017 Share Posted January 29, 2017 Both the coils I have are genuine nippon denso ones. All og. Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 29, 2017 Share Posted January 29, 2017 memories - starlet alternator shat itself and would test up fine at idle, then jizz out 17V or more when being driven. ?? Quote Link to comment Share on other sites More sharing options...
