Centerless rims
  • Please log in to reply
35 replies to this topic
#1 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 06 April 2008 - 05:57 PM
Hay people im after 14 x 9 barrels? They come that wide or would i be better of getting mine widened?
Also if so How much per rim? Anyone got hook ups?
#2 Requiemk
Requiemk
  • Members
  • 1,785 posts
Posted 06 April 2008 - 06:02 PM
are you after steel or alloy? i think finding alloy once would be pretty hard. Elite wheels will do em in steel.
#3 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 06 April 2008 - 06:06 PM
Steel
#4 kyteler
kyteler
    BARK
  • Members
  • 25,331 posts
  • Local Area:
    Southland
Posted 06 April 2008 - 06:17 PM
Elite will likely do them, but PM Cam, he used to get hookups in that regard and still has connections IIRC.
#5 Bistro
Bistro
    pube swallow
  • Moderators
  • 3,578 posts
  • Local Area:
    Wellington
Posted 06 April 2008 - 06:33 PM
yea pm cam first cos i think they might do that size.
be all like, PM!PM!PM!PM!PM!PM!PM!PM!PM!
Club '33: Welcoming BVB as a friend!!
5M-GE wakas are what magic is made from
#6 Guest_sexychevette_*
  • Guests
Posted 06 April 2008 - 07:32 PM
just ring TWL to find the info on the centreless ROH rims. Theyre the ones that stock em. Elite get 'em off 'em. Should be able to find an engineer up your ways to put ur centres in
#7 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 06 April 2008 - 07:36 PM
yes no problem getting em in jus want cheap barrells
#8 mikuni
mikuni
    Bradkuni
  • Members
  • 10,268 posts
  • Local Area:
    Waikato
Posted 06 April 2008 - 07:56 PM
they only go up to 8 inch but if you get centreless rims you might be able to mash a 1 inch band in there aswell? They are about $300 for 4 so not very cheap.
Those wheels are just ag wheels anyway. I found some banging ag wheels for on one of those mean suzuki quad truck things and they were available in 4x100 but only up to 12 inch at that place. He said he got them from whanagrei imports, which is that big warehouse along the straight thats just after onerahi if you are heading to the heads. Apparently they bring in heaps of centreless and blank rims so deffinately give them a go.
If you do just get that cunt to widen them make sure he flips them too.
#9 Gaz
Gaz
    Get Rich to This
  • Members
  • 15,577 posts
  • Local Area:
    Wellington
Posted 06 April 2008 - 10:55 PM
Widened 12" could be banging as!
#10 mikuni
mikuni
    Bradkuni
  • Members
  • 10,268 posts
  • Local Area:
    Waikato
Posted 07 April 2008 - 11:37 AM
12's and even 13's probably won't go over the brakes.
Find some tyres that will fit on 9's before you go with them because I think 14" tyres are a little bit hard to get in a nice width. Shane would probably be able to stretch 195's over 9's though so you should be sweet :lol: Just something to keep in the back of your mind.
#11 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 07 April 2008 - 11:43 AM
195 45s look the bizz bro,
#12 Leebo3
Leebo3
    Chop pouch
  • Area Reps
  • 4,647 posts
  • Local Area:
    Northland
Posted 07 April 2008 - 01:32 PM
This may be some help
http://www.performan...teelwheels.html
Edit: they only do 15s other than 14 x 6
#13 Guest_sexychevette_*
  • Guests
Posted 07 April 2008 - 02:13 PM
why 9's? just get 8s from TWL. its like 40 a rim with trade...i think thats what i got mine for. Yeah u can band out the ROH rims. Engineer i used said easiest way was to buy another pair and then he could cut them up to widen the other rims
#14 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 07 April 2008 - 02:31 PM
Ewe no
#15 nobumps
nobumps
    Post Fiend
  • Members
  • 709 posts
Posted 07 April 2008 - 02:32 PM
No there not there the same rims as on the jetta currently??
#16 mikuni
mikuni
    Bradkuni
  • Members
  • 10,268 posts
  • Local Area:
    Waikato
Posted 07 April 2008 - 03:18 PM
What??
#17 Ke36
Ke36
  • Members
  • 1,154 posts
Posted 08 April 2008 - 09:26 PM
i made keen to do this for drag rims to fit decent width rubber, skids etc
do they do 15s aswell?
could just do 14s iff need be
where do i get centres from need 4x100 aswell
#18 drftnmaz
drftnmaz
  • Members
  • 1,313 posts
Posted 09 April 2008 - 10:52 AM
for centers you just cut up some old rims.... so whos got hook ups at TWL? $40 a rim sounds like a sweet deal to me
#19 Guest_sexychevette_*
  • Guests
Posted 09 April 2008 - 12:57 PM
yeh just make sure u measure the centres u want to use to make sure theyll fit inside the roh rims properly. a couple mm too big is ok but im not sure if itll work if theyre slightly too small.
the engineer i used could get hookups at TWL. i think they were like 60something retail. or something
#20 Dolan
Dolan
    EXCESSIVETROUSERPLEATS
  • Members
  • 22,099 posts
  • LocationGOOBY PLS
  • Local Area:
    Outside NZ
Posted 09 April 2008 - 06:20 PM
70 something at retail plus tax, look to spend around 50-55 with a hookup, plus tax. they go 8 wide, frm 13s to 15s, max. mean
