tortron's minor
fuel
  • Replies 272
found vac gauge and sorted out distributor timing
running much better - tho i think the mechanical advance (no vacuum advance on this bad boy) wants freeing up, also new rotor as its quite slack
picked up spare engine and box
probably wasnt running due tot he timing be 90 degrees out
also it has a later a series distributor with vac advance rigged up - may have a play with that, tho im told its not any better
have been doing a small amount of rust repair - and a LOT of sanding over the last month
currently starting to put primer back on and going over it again to find any little bits i have missed
shouldnt be too long now before i can start putting it back together. Will need to do a bit of a shop for new seals and rubbers (already have them for all the windows and the bonnet, have made others for the boot/bonnet hinges and badges) as most of them were stuffed
drop it low and let be hear your hips schwing
this needs rack, sack and flap, asap.
How much longer before on the road again?
as soon as i can breathe again so i can wear my mask itl get painted
this week/early next week stz
probably kick into the interior, boot and door jams tomorowish as i have just cleaned out my gun in preperation
i figure 3 months isnt all that bad considering its been a little more than just sanding - i.e. it wouldnt have passed its next wof due to new rust
still need to order various rubbers for putting it back together, tho nothing real important to its functioning
just windlace for the doors, lower seals for the doors, boot seal and possibly some light backing rubbers as mine were a little crusty. Oh yea -also a bunch of bolts as i broke most in removal
also - i have all of the above sorted :wink: (actually i need some u bolts)
