sheepers 1976 RA23
sheepers
  • Replies 145
  • sheepers
    146
engine/gearbox removal.
it begins. i thought it a good idea to do a compression test before i took the motor out. very consistent readings of between 160 and 170.
well, on the front 5 cylinders there was, number 6 however decided that 70PSI was the most it could muster.
so the motors fucked and will need a rebuild.
tomorrow more motor disassembly .
26546305006_8f5c572c69_h.jpg2016-04-22_08-20-19 by sheepers, on Flickr
26546303366_d6e15f0b4d_h.jpg2016-04-22_08-20-10 by sheepers, on Flickr
26506345001_91f6ed7a09_h.jpg2016-04-22_08-20-03 by sheepers, on Flickr
26506343631_aaa52a19d4_h.jpg2016-04-22_08-19-56 by sheepers, on Flickr
26572411315_87b7472306_h.jpg2016-04-22_08-19-48 by sheepers, on Flickr
26480067352_ccd78ab457_h.jpg2016-04-22_08-19-33 by sheepers, on Flickr
25969532903_757e4a303e_h.jpg2016-04-22_08-14-06 by sheepers, on Flickr
  • Like 6
  • 4 weeks later...
had a couple of issues that are a bit weird/stupid.
firstly the fuel rail came loose, or i didn't tighten it properly which resulted in it having weird vacuum issues at idle. caused it to be a bit rich but that problem is fixed.
secondly the crank angle sensor shit itself or some reason so i need to replace that.
and finally the turbo bearings went fucked. i made the oil drain to small and it pushed oil out the seal into the exhaust but that shouldn't have had any effect on the bearings. they definitely had plenty of oil. but for some reason both shaft bearings and the thrust bearing are fucked. very strange that one but thats what happened.
so I've fixed the oil feed and drain, ill order a new crank angle sensor tomorrow and Brendan is fixing the turbo.
in theory it should be back on the road by the end of the week.
  • Like 7
yea, so it goes really well now. 14 pounds equates to about fuck all rpm so its interesting  to drive. its got a LOT of pull from basically idle and it makes boost almost instantly. the joys of a small turbo i suppose.
now to do some more Ks in it and see if anything wants to have a melt down.
it would be nice if this is the end of things shitting themselves.
  • Like 8
Richard who bought the red car got some angry ducks laser cut for hit center caps and he gave me a set to play with.
i made some combination hub centering rings/center caps the other night so i thought id attach the ducks to them.
the plan is to paint the ducks and the cap screws blue then clear over the whole lot.
probably have a crack at that tomorrow.
29179101921_cf9537453b_h.jpg2016-08-27_05-04-19 by sheepers, on Flickr
