Raizer Posted March 6, 2007 Share Posted March 6, 2007 Stuff needed; · One pair of Volvo 140, 160, 140 or 260 front brake calipers. Be sure they match (vented/solid) the discs you will use. 140 and early 240’s have solid front discs. Some Volvo's had Girling calipers, others had ATE calipers, · A set of brake pads for the above · Two brake line “T”-couplings · Four pieces of brake line (approximately 15 cm each), with “male” fittings each end, to suit the T-coupling and the Volvo caliper · A set of vented 2.8i Capri discs, or standard Escort solid disks if using 140 or early 240 calipers · A couple (4 at least) of M12 washers · Normal hand tools (a vice is great to have) Get to work 1. Loosen the front wheel nuts, and jack up the front of the car and support on axle stands 2. Remove the road wheels 3. Place a bit of plastic sheet film (like the one used in the kitchen to preserve food…) over the brake fluid reservoir opening (remove the cap first…). This will reduce the amount of brake fluid that runs over you hands later… 4. Loosen the brake pipe fitting in the Escort caliper, and either remove the entire brake pipe, or bend it out of the way. If this pipe is in good nick, it can be reused, so be careful. 5. Remove the brake caliper 6. If you need to change your discs as well, do that now. This would also be a good time to replace the front wheel bearings. 7. Compare the old Escort caliper to the Volvo 4-pot. You will notice that the mounting holes are spaced a bit different. 8. File the mounting holes in the Volvo caliper to an oval shape, to match the mounting lugs on the strut. Take care to file both holes approximately the same amount. Note that the calipers mounting lugs already are shaped to accommodate the oval hole. 9. Trial fit the caliper on the strut, with the brake pads fitted. Check that the disc is “centered” between the pads. If not, pray that the difference is “the right way”, so you can use washers between the caliper and the mounting lugs to achieve this. 10. When you’re satisfied with the centering, tighten the mounting bolts. 11. Trial fit the wheels you will be using, and check for clearance. If they are 14” or bigger, there should be no problem. 13” “Ghia” alloys just clear the caliper. Hotwires etc should clear as well 12. Now it’s time to fit the brake lines. As you can see, the Volvo caliper has two inlets. This is where the “T”-coupling comes in handy. Either mount the T directly on the Escort flexible brake hose, or to the end of the old brake pipe on the strut. Then carefully bend the 15cm pieces of pipe to fit the caliper inlets. You might want to add a brace to the T-coupling to mount it steady. Vibration is not good for brake pipes. 13. Check all connections and bolts for adequate tightness. 14. Top up the brake fluid reservoir 15. Bleed the front brakes. There are three bleed nipples on the calipers, take the two on the side first and last the “top” one. 16. Check the brake pedal – it should not feel spongy or “bottom out” against the floor. If it does, bleed the brakes again. If this doesn’t seem to cure the problem, you will have to fit another master cylinder. See below 17. Remount the wheels and put the car on the ground 18. Test drive carefully! A new master cylinder? Sometimes the standard Escort/Capri/Cortina master cylinder can’t cope with the new calipers. There are several options here. A Land Rover item (LR series III Standard double circuit master cylinder Lucas Part No. FMK177 (or equivalent)) should work, or you can use a Volvo 240/260 master cylinder. This will need some altering of both the master cylinder (new holes drilled) and the linkage (the push rod to the pedal needs to be extended by about 20-30mm). You may also need to incorporate a brake proportioning valve to prevent rear wheel lockup. A change in master cylinder may also mean you have to alter some of the brake pipes. Edit: BMW DISCS A good disc/rotor up grade to go with these calipers is from a E30 323i BMW with a little bit machined off them Sorry its blurry, thats 2mm and 2.5mm Link to comment Share on other sites More sharing options...
