Gaz Posted October 18, 2006 Share Posted October 18, 2006 Torque all in lb f ft Mains caps - 64.5-74.5 Flywheel - 46.5-50.9 Big end bolts - 29.7-34.7 Oil pump - 12-15 Pump cover - 6.4-9.3 Sump 1st - 1.4 2nd - 5.7 3rd - 7.5 Head 1st - 15-30 2nd - 36-51 3rd (after 20mins) - 54-61 4th (after warming up) - 70-85 Valve clearances (cold) mm Inlet - .008 (0.20) Exhaust - .010 (0.25) Sparkie gap - .025inch (.60mm) 18mm plug Contatcs/points .45mm Motorcraft .45mm Bosch Firing order = 1,3,4,2 Give her 8° BTDC @ 800rpm Link to comment Share on other sites More sharing options...
