Everything posted by chees-
yea they dont come solid axle F, you're right it will be E i'm pretty sure
How did you manage that???????? ALSO PLEASE SLAM THANKS
Na with 61s the trailing arm is cut to fit the spring so the perch sits above. I ran the spring perch with no spacer, mine wasnt as tight as yours though it seems.
are you sure? i managed to get some non genuine items for my gx61 via north shore toyota, i can't imagine a 71 being any different?
rebuild, its in pieces atm just need to commit to a bbk also like that exhaust touches the ground when i sit on it haha
fuck yes
You have to cut the silver lower section off before you weld, otherwise yea they’re a bit shit
Can you bone front to match rear?
I’m like 90% sure this is my old piece of shit, history behind it: was used as our farm hack for ages hence its a bit fucked, and i think the fronts bent? Then i drove it to the ferry and back till it died on me, thought i’d buggered the rings but looks like it was just spark? I sold an fz with it too so i wonder if thats the engine your mate got.
That will defs fail, grind it back, rust kill and paint it. Ease as
I'd say your belts worn to shit, grab a new one of those and chuck it on
Yea fair enough, they look fucking good with max slam on 8" wheels. Cant quite get the same look with the dio sadly. still keen to swap wheels!
ummm swaps? seriously haha. i want max bone on mine so small wheels is tops /swap whole scooter haha, i've got an af18 dio that goes fucking good after i've done a bit of fiddling to it. High speed variator, dr pulley style rollers, fresh belt, nails it up to speed now and still does 65-70k fairly easily. i think its pushing 80 downhill.
DJ1 is sweet, i'd be keen on it if you ever want to sell
flogged its crank keyway. he's sold it already.
looks to have a fairly decent amount, just wider spread from the fat hub makes it look like fewer.
yes but there is not a consistent surface to press against like a lip, so you'd be constantly sticking fingers/hands into your rotating wheels which would = painful at the least
i cant imagine that going to well with spokes
looks like my anus
so i painted it white and it looked like this: But the white was off so it bugged me, rather than redoing it creamy i figured i'd try pink, what a fail. so now im going have to paint it back too white again haha, will try get the shade right this time
