nzvohc's Achievements
Advanced Member (3/5)
151
Nice work, and good to see a 2 dr HC getting some love. Liking the choices you are making with grill etc and putting the car back to something near original. They're thin on the ground these days, look forward to seeing where this goes.
Andre's vauxhall magnum into Firenza droopsnoot project
nzvohc replied to yoeddynz's topic in Project Discussion
Cheers...it's actually a bigger job than I imagined it would be, but glad I didn't think too much about it before starting, otherwise I may have never taken it on. Amazing to hear off what other people have done around the country. The Chevette would be interesting to see. Do you know if they were Lotus or Vauxhall engines? -
SillyVohcer's Vauxhall Firenza "Droopsnoot"
nzvohc replied to nzvohc's topic in Projects and Build Ups
So as mentioned earlier, the front end got a tidy up with a coat of paint. This should help the leaking oil clean off easier in future. One benefit of these engines is the fact that they were developed and modeled off the Vauxhall slant engine, which includes the exact same mounting points on the block, so it was a simple case of swapping the Vauxhall mounts onto the Lotus block to set the engine up in the same location. This was really important to me as it meant that the gearstick location would end up in the same position as before, but more importantly the driveshaft length stayed the same with no need for any mods. (I was already running a W50 gearbox behind the Vauxhall engine, so the yoke matches too) This the first fit to subframe. Note the exhaust manifold was removed by now as it fouls the mounts and can't be used. I had hoped I could avoid the need to replace these simply to keep the initial cost down and replace it later with some headers. So it just means I have to do it sooner rather than later now, likely to be in S/S. I am going to attempt mocking up a set of extractors while the engine/subframe are out of the car as it's so much easier to get around, and then have them made off site, we'll see how that goes...this is a pic of the header flange I have had laser cut in MDF to check fitment, which once happy with will be sent to engineering shop to be cut from 10mm plate. Of course I would like to just buy a set of these...anybody want to chip into a GoFundMe account?? Worth a shot...but don't they look sexy??!! A couple more pics of first fit. Although it looks good here, the sump is actually touching the cross-member. The Lotus block is quite a bit wider at the bottom end than the Vauxhall, so there will be no avoiding cutting the sump to make clearance. The headers you see at the bottom of the photo are a spare set I have from friendlyfire's Chevette from when he had a Vauxhall engine in that. I was hoping I could possibly adapt these for this conversion, but they would require changing so much that I may as well start fresh, in S/S. I gave the cam covers a tidy up around this time too by carefully sanding the paint off the raised lettering etc, which looks way better. They really need refinishing and will be done at a later stage as not a high priority at the mo. May change the colour also, any suggestions? The orange filler cap will have to go too. So before tackling the issue of the sump I want to check my theories that the engine/gearbox would sit in the right position and clear the bulkhead etc. I rolled the assembly under the car for the first time and carefully lowered the car back down onto it. By the way, I am not lifting the car from the slam panel, as it might look like here, I am lifting it via a heavy steel tubing that is tucked under the chassis rails you can just see in the next pics. Almost there... And in! Yes, the bottom cam housing is millimetres away from the bulkhead and too close to leave like that, which I have a plan for. But hey, it's in! Next the sump cut.- 22 replies
Yoeddynz's 1975 Datto 120Y wagon restoration.
nzvohc replied to maddat's topic in Project Discussion
I think secretly you just love cutting out rot...you could have been a dentist...the principle is the same...take some "before" photos, scratch your head, dig, grind, fill, make small talk, grind some more, collect loads of money, repeat... Just a thought. Nice progress btw. -
So many ways to rhyme naughty words with Photobucket to describe them it hardly seems fair... Definitely good to get that battery tray off with minimal damage. I have seen other cars have far worse to deal with stemming from this area. I ended up taking the window washer bottle bracket off too and will remount that down lower where a bit less visible. -
Thanks for tips @Truenotch I figured I might be up for doing that job sometime. I don't blame you for forgetting it existed either, I've kind of done the same occasionally over the years! -
Ok, next was to get the engine home and start the transplant. It's going to be tight in there! As you can probably see in the background, I had pulled the engine and subframe out of the Firenza by this stage to clean it up and paint it. This is the engine bay as it was before starting. Got to get rid of that green! And the old donk out. The process involved using a engine crane to lift the car up away from the subframe with engine in place, then place jackstands to keep the car in the air so that the crane can be wheeled out of the way, then roll the subframe forward and out from under the car. I could then use the crane to lift the engine of the subframe . It's a process that's for sure, but has worked well and it's great to have the subframe out of the car for pre-fitting the new engine. The next step I took was to prep the engine bay for painting. Before that though I installed a new clutch master cylinder and converted the clutch pedal from a pull-cable to push-rod. I don't have pics of the pedal mods at the moment, but here is the cylinder in place, tucked nicely in alongside the brake booster. Yep, it's snug! Then everything stripped out. . I could see problems lurking under the battery tray and knew that it would have to be removed to investigate. Sure enough, nasty stuff but thankfully only surface rust. Will relocate the battery to the boot and remove the tray permanently for a less cluttered look. After that was taken care of, the fun begins with prep work. Got to love all those fiddly shapes and edges in an engine bay! I decided on painting the engine bay black, as that was how the "Droopsnoots" were factory done back in the day. Borrowed a compressor and gun from work and squirted it. I'm not entirely happy with the finish up close so it may get another shot later, but for now it is much improved. About this time I also acquired a personalised plate for the car. This plate had been on the car many years ago when it originally had a very rare & genuine Vauxhall TC engine. The engine and plate were removed by a previous owner and used in a Chevette HSR replica rally car. A shame not to have that engine now, but this new one will pay homage to it nicely I think.I have a pic somewhere of the old TC engine which I will find and post. He still had the plate and I was able to convince him to part with that. Next up is numerous trial fittings of the engine and subframe to get the engine/gearbox in the right place. More tomorrow. -
Pause to fix pics. -
I've reactivated my photobucket account tonight, so hopefully all the previous pics will be visible soon. If you've read through this thread you'll see that I purchased a Lotus 907 TC engine some time back for transplanting into the car. Either that or taking the head off it and adapting it to the Vauxhall block, which is possible due to the engines being so similar. It's a nice option because you get a TC head and 2300 block that doesn't require modifying anything from the head down, as opposed to a full engine transplant and all that goes with it. Here's a pic of that conversion somebody else has done. And here is a pic of the Lotus 907, in case the ones above never show up again It's a nice little unit, but a little low on ponies at about 140hp, and I would like a little more, as you can get 180hp out of the Vauxhall unit with fairly basic mods. So this sat for a while as I contemplated the best direction, and even started getting some of my Vauxhall bits together on an engine stand to build a good all Vauxhall engine as a simpler solution. I will likely still build that engine in the future, but it will be for my GT Viva. In January last year my TM feed came up with another engine which really got my attention. In the many years I've been scrolling through classifieds I have never seen one of these come up before and it was at a price I could justify. So after a discussion with the seller to work out exactly what the engine was and it's general condition I knew I had to move on it. This is another Lotus unit, but a later version of the of the 907. It's a 912HC (High Compression) 2.2L unit from a 1986 Lotus Excel, rated at 184HP and factory mated to a Toyota W58 box and hydraulic clutch. All very modern! This is how I received it, in all it's glory. (There is also an interesting story behind the car this came from, which I will post later.) These engines went through a series of HP upgrades over the years, from the 907, to the 910, then the 912 like this one, and then on further to be turbo charged in the Lotus Esprit, rated at 215HP. More mods were seeing figures closer to 300HP made by those brave enough to try. The 912 also has an updated head/cam design which I am lead to believe successfully eliminated oil leaks from the cam covers. The car this came from had both power steer and AC, so the engine had the associated pumps, which were the first thing I took to removing before giving it a serious degrease, (although it was a visually very dry engine, more just years of grime) which saw it going from looking like this... ...to this. Much nicer! Can actually see the engine now! Then a compression and oil pressure test were done, and both came up to factory spec. Much relief! -
So, time for an update on this ongoing build, just getting my pics in order from the last year or so and will drop a bunch on here soon with some wordage. Meantime I'll add a teaser for now...cue sexy music...- 22 replies
nzvohc changed their profile photo
We plan to get to the boat show, always worth the drive and a look around. What day is everyone thinking? It's on Sat & Sun. Blenheim Hospice Classic Car Show is the following Sunday 12th too Went last year for the first time and was impressed with the turn out, plan to go again this year with the Firenza. Anybody else making the trip?
Yoeddynz and Hannah's HB Viva Wagon Discussion
nzvohc replied to Willdat?'s topic in Project Discussion
Congrats on getting legal beagle, it's a great feeling after a long haul! Pics look great. I think you should try and pick up an old surfboard to mount on the roof, would really suit. See you at the meet. -
Hey maybe Hannah can set to cleaning the moss off the windows for you, I think that would be really nice of her...cos you know the rest of the car is going to have to follow the example of the engine bay right? If you are wanting an old radio to complete the look inside I have a few spare, I'll bring them next time we come over. Keep up the good work, looking forward to see it on the road soon. -
A few glamour shots from the Vauxhall Nationals in Oamaru. Next, the engine...see you in a couple more years!- 22 replies
