About matt_spitfire
- Birthday 07/19/1988
Gender
Male
Local Area
Nelson/Blenheim
matt_spitfire's Achievements
Advanced Member (3/5)
288
4agze intake manifold making a strange noise..
matt_spitfire replied to matt_spitfire's topic in Tech Talk
Problem solved, excess vacuum inside the intake manifold. -
4agze gurus: Anyone have any idea what may be causing this sound? It’s coming from the intake manifold on a ae101 4agze map model engine. Sounds like a pipe trying to suck up fluid.. please note engine always has an air filter on it just removed to record the video. Only makes the noise on idle after cold start knocks off. Seems to disappear when’s revs are on an comes back when revs drop. video: https://youtu.be/_u0iICeAu_c
Matt_spitfire's TA22 Daily Driver build/resto
matt_spitfire replied to matt_spitfire's topic in Project Discussion
No 3sge although it was a serious consideration, its quite a tall motor and i would have had a few clearance issues ect.. How ever i did do this in December when i got back from Mexico. -
4agze cold start signal wiring question.
Problem solved! Black and white wire was the answer, has 12v only when in the start position. Admin delete if required -
Hey team, I'm just finishing up the wiring on a 4agze. Ive got one of the easy wire looms. It basically goes like this.. 4agze loom 5 wires, 3 of them I need to hook up to my factory ignition switch which has four wires so should be pretty straight forward 1. Blk/red wire on factory ignition switch has constant power with ignition on and off and doesn't lose power when starter cranks - I've hooked this up to yellow constant wire on 4agze loom with 5a inline fuse. 2. Blk/white wire on factory ignition switch Has 12v when ignition starter cranks. 3. Blk/yellow on factory ignition switch Has 12v when ignition is on in acc's position and drops to about 9v when starter cranks. 4. Blu/red on factory ignition switch Has 12v with ignition on and drops to 0v when starter cranks. and finally we arrive to my question, there is a small black wire on the 4agze loom which is the starter signal for the ecu I assume this is for the cold start injector.. Basically I'm just after confirmation which wire I should hook into on my factory ignition switch for it to get the right signal when the starter is cracking over? The two wires on the 4agze loom I havnt mentioned are for the alternator and fuel pumps so don't need any info on these. cheers! - matt
Cheers Cletus, I'd just be getting the engine mounts and rubbers not the gearbox crossmember
Im looking at buying some engine mounts for my ta22 from KE Conversions in aus, he uses 3mm plate can these be certified? Link for mounts here: http://www.rollaclub.com/board/topic/61198-4age-to-ke70-ke30-ke20-and-ta22-mounting-kits/ Cheers!
does anyone know the minimum thickness of steel plate required for engine mounts to pass cert, is it 3mm? looking an buying some pre fabricated ta22 engine mounts. Cheers -
matt_spitfire replied to matt_spitfire's topic in Projects and Build Ups
flikr wont let me upload images to forums now can anyone give me a good recommendation for an app i can use to upload and code images for a forum? cheers -
Is there any interest in my mighty 2tg out if this thing? Going a different route so maybe up forsale. Some deets: 2tgeu converted to twin side draft Mikuni solex twin side drafts with custom linkage set up and ramflo filters Custom extractors New leads New dizzy cap New oil Can come with 3tgte flywheel, clutch, bell housing or 2t flywheel clutch also a pare motor 2x spare EFI I take manifolds, complete EFI engine Loom and multiple Starters ect Let me know if you're interested as need to free up some space and funds for new engine conversion. Cheers -
Sorry.. its been a while.. over i year i think.. the car is still alive and in my possession, it drives and stops etc but no cert yet as i keep changing my mind, hopefully she'll be back on the road this summer. Pic for bump reasons.. spot the difference photo by matt postle, on Flickr On another note, can anyone point me in the right direction for rear louvre clips auger or similar???- 78 replies
Hey man, sorry i havnt been on here in months!, project is on hold at the moment while i source some parts for it.. theoretically i could put it through cert now but i would have to get it recerted once the alternative parts arrive. it starts stop and goes though! Hows your project coming along? I saw youve been hitting up strungout and papa roach in the states, id give my left nut to go do that shit! -
Because im lazy.. and havnt made any updates in 8 months or so.. its close but still got a bit left to do. ill fill in the blanks when i get time.. image by matt postle, on Flickr image[1] by matt postle, on Flickr image[2] by matt postle, on Flickr image[4] by matt postle, on Flickr image[3] by matt postle, on Flickr image[5] by matt postle, on Flickr- 78 replies
- 23
Has anyone applied for an exemption through NZTA when no plates or previous history of registration in NZ are available for the vehicle? Got my change of ownership letter of interest for the police but still can find out what my celicas old plates were.. Got told that if i cant find and history on my car then i can apply for an exemption at $184 p/h to process with no guarantees that it will be approved or how many hours it might take.. Cheers in advance
