matred
    Christchurch
matred's Achievements
Advanced Member
Advanced Member (3/5)
0
  1. Have you got a few details on the mounts to put motor in?
  2. Would you mind uploading a few pics of your intercooler install. What kind of intercooler are you using I've found there's not much space to fit one
  3. Don't worry just seen you said pre hq.
  4. So wheels of a hq are 5/108?
  5. Yea I measured it like that and they are 5/120.
  6. How is it measured, do you measure from middle of stud to the one opposite. My ones are close to 108mm across them like that.
  7. What stud are vk commodores. I'm thinking of buying one without wheels and I've just got some 5x120 steel rims to put on. I've read somewhere that 4 cylinder vk's are different than a 6 cylinder.
  8. Do you still have that 2l turbo stuff. If so i'd be keen to buy it?
  9. Na going have a look soon
  10. Just put a 1500 out of a 86 wagon into my hatch. Problem is the plugs of the hatch loom are different to the ones coming of the wagon engine, and theres a extra wire coming of the engine loom which has no where to go on the hatch loom. Should i just connect all the wires together instead of using the plugs or get a engine loom from a 1300 what use to be in it.
  11. How much did them rims end up costing to get widened? Wherebouts is he in mot
  12. http://www.3ballsracing.com/index.php?option=com_joomlaboard&Itemid=40&func=view&id=875&catid=3&limit=15&limitstart=0
  13. Wanting to get some widened steels made for my ke70, would any engineer be able to do this? Has anyone got them done around here before. cheers
  14. Where did u get that 22mm sway bar from whats it off
  15. just want some to put in my 323 hatch but really looking for fishnets.The guy reckons they go up and down so should be able to get them out some how
