Borgweiser
About Borgweiser
  • Birthday 08/23/1983
    Wellington
Borgweiser's Achievements
Committed (5/5)
742
  1. You sick man, I also have a 99 sedan and a 900 Aero coupe. These kick arse, I also have a load of NOS SAAB 99 bits and some secondhand bits- I know all the SAAB Barries/Bjorns
  2. As always there's a trick to it same with the later 900, if you have the correct tool to hold the clutch together when compressed it slides out after unbolting from flywheel. You need an assistant to push down clutch. Book time was 45 minutes for the whole job
  3. I have a transporter here, if it's not too much of a drain in time I can sort. Got four big builds on that are overdue for completion.
  4. Oh wait, your grandfather IS one of the Skoda Barrys. I got the indicator lenses from him via you. Good to see you got hold of this wicked whip, now please change the wheels to Fuchs thanks
  5. Here's the best pic I can find of mine, when it was in daily use. I still have it- great cars. I have plenty of parts at my disposal and know all the Skoda Barrys if you need things.
  6. I've been here before, the HIF44 SU ain't a barry spec carb, but a top notch swap on basically anything that's plagued by complex emission crap. A single one of those would be more than adequate. But bike carbs will sound and look cooler. Go for Mikuni's, basically miniature Japanese made SU's anyway
  7. I wondered who these hipsters blocking up my hood with cameras were. Can lend the 91 Volvo 240 for the cause. Edit- working on photos, computer is doing a dumb - Blue Renault here currently, Morris is street furniture even now in NZ, Volvo very 90's (having grown up in that area in 92, all the cars in the background should be from the seventies. The newest car in the neighbourhood was an 89 Falcon. Just my 2c)
  8. Ford, FIAT, Simca, BMW, Opel all used a 32/36 DFV or DGV. Same carb but mirror image of each other. Hugely popular as a replacement for most carburettors of the era Much better than a Zenith or in this case a Stromberg, new ones available cheaper than rebuild. As for the breather not important unless it's fumey, get a gauze type filter kit that most 32/36 use and you'll find there's an elbow to attach the breather pipe
  9. Just read through first page and last, seems like you got it found if you ask me. Hub flanges sound out of whack. get the bearings off and studs and drop to Karl at Cemeck engineering. He should be able to true them up or at least give a good opinion on them. Probably has good ones somewhere in the shop knowing him
  10. Regarding front wheel dilemma and reading through the thread I may have some advice. MGB front discs should fit with a bit of matching of kingpins and the likes but not sure if it's a complete bolt over job. The two share a common ancestor. I used to work on a mad Wolseley 16/60 in Auckland for a customer, with a 260 Ford motor, the Y block having the right dimensions and of course the best sound the yanks have made to date. In that situation with the added weight and power, we cannibalised the discs and five stud hubs off the six cylinder as well as the tougher back axle. Loads of ratio options and the diff at least was a bolt in job. Loads more wheel options too. Ended up with Rover P5 Rostyles on it which suited it, the other less fun option is get an earlier Oxford drum and shoes, the later cars had an extra half inch of material hence weird shaped drums.
  11. So many horror stories about when it comes to panel work, sadly I can name you a hundred places where not to go. But not many off hand I'd recommend, I just had some work done by Classic and Modern, again heaps of good and bad said about that place (sure others here can add) but the panel work was great, I just had metal shaping done and left in primer, paint finish on some of their jobs is average but was happy as with the metalwork- maybe split jobs between places?
  12. Had one same year same colour recently, 22 thousand original miles and amazing. Loved it apart from the shocking steering. Just a FYI on the fuel pumps, I've fitted Lada type fuel pumps to Peugeot 504's which are two litre and never had an issue with starvation even during mad dorts. Check out the leaks but then check the hose at the tank end and the pickup in the tank, I've had to rod them before to get the crud out. Pause.
  13. Keen to come along, has anyone actually checked they're open tomorrow? I've been past a few nights the last month and they've been closed- tonight even at about six pm...
  14. After a load of work, time and two new owners.. It's come back, I enlisted the help of professionals to make the super complex rear lower guards. Pulled motor out for valve grind and clutch and now debating whether to OHV and 1725 it, kinda glad this thing has come back into my life- always regretted selling it.
