cletus last won the day on March 20
cletus had the most liked content!
About cletus
Gender
Not Telling
Local Area
Auckland
cletus's Achievements
Committed (5/5)
62.1k
Gang members also have access to the information, you could try your local motorcycle club? ‘Significant breach’: NZTA employee passed on personal details for drugs | The Post VTNZ conducts review after privacy breach by Head Hunters' ghost unit - NZ Herald
Yeah it's not great to mix radials and bias ply tyres, it can make for some interesting handling Nzdra rule book says
Probably should have them, because of bias ply Hoosiers on the back, but when those are worn out I might try some drag radials , so would need a radial on the front
Good to see a new project! What happened with the viva? Kinda bummed you didn't finish it, was a cool car
Not sure yet, I usually struggle to get there on time after work/traffic/probably overheat in the southern traffic jam
Bart, your ute I like.
Yeah something like that would work
The steel wheels on it are very heavy. When it did its quickest time it had some very light cragar super tricks on the front. They were popular in the 70s but the internet reckons there's not many around these days because they were prone to failure. I bought them ages ago from a guy who took them off his car because they made creaking noises when doing tight turns, they were very cheap. They weigh as much as a bag of chips and are a bit sketchy, also the tyres were right on the limit speed rating and load rating wise. Plus I had to run a 5mm spacer which I did not like. I only did 2x passes with them on and didn't like it So I've had my eye out for a second set of wheels suitable for drag racing Being an impressionable teenager in the 90s who read street machine magazine a lot I've always wanted a set of weld draglites. They don't come up often second hand, I found a set a while ago but they were not wide enough. You can still buy them new but they are pricey Picked these up today, 15x5 and 15x8. Tried them on then got the tyres off, they are very fucked. They need a polish but should tidy up well Anybody know a good polishing place in south auckland?
- 128 replies
- 24
Yep. You would likely need to add something back in to make it strong enough/roughly the same strength as it was. Wouldn't need anything complicated
It's not particularly difficult It is intended to be used by people modifying cars, to help them with their projects. there is a range of people with different abilities sending applications through and they all get looked at, they are not viewed as wasting anyone's time. Some are hundreds of pages long with cad drawings and FEA paperwork, and some are literally hand sketched drawings. Photos are very helpful in an application You will probably struggle to find someone to teach you how to do your particular project as it's quite different , so there isn't going to be anyone with a recipie for exactly what needs doing. Certifiers can guide you along the way but, time is money, if the certifier is willing to help design the car/mods you're wanting to do, it gets expensive quickly Time is the biggest factor when getting people to help you. It's not uncommon for me to spend 2-3 hours a day on the phone, talking to people about their projects, emailing , looking at parts etc etc. This ends up eating into the time I have to do work I can actually charge out- there has to be a balance and this is why it can be hard to find people who can help you lvvta.org.nz you can download a design approval application from there There are also infosheets on design approval https://lvvta.org.nz/documents/infosheets/LVVTA_Info_11-2012_LVVTA_Approval_Application_Guide.pdf https://lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2016_LVV_Custom_Independent_Front_and_Rear_Suspension_Approval_Application_Guide.pdf
Not required Will need mud flaps though
Yes. Fuel and brake lines. I usually recommend running them away from the driveshaft where possible, as a rear loop on a solid axle car is (a) hard (b) looks stupid (c) not particularly effective Not quite as bad on something with IRS
Probably fine, by the time there's a weld there it will be pretty much at the bottom
What's a good running K24 worth? I had a look on trademe but there's none on there at the moment I'll likely have access to one soon, and it's in a handy take home package
I remember reading about them as a kid and being "whoa" at 2l turbo 4wd in a hatch Never had much to do with them apart from fixing one for a tight arse car dealer customer we had, it was a fill in job for when work was slow so it ended up taking 4 or 5 months , it broke a ring land so the car dealer supplied 1x second hand piston. Did it with the engine in place, getting the head/intake manifold off counts as one of the worst jobs I ever did Also due to the fact it took so long just doing bits here and there, when I started it I'd forgotten I'd removed the oil filter. It was on the hoist, fired up, pissed oil everywhere, I reached in the window to turn the key off but it had a turbo timer down by the console so I had to do a panic dive in the window to turn it off, the boss thought that was quite funny seeing me with my legs sticking out the window
- 27 replies
