Scrubb
About Scrubb
  • Birthday 10/26/1986
  • Gender
    Male
    Waikato
Scrubb's Achievements
Post Fiend
Post Fiend (4/5)
194
  1. You might be on to something there. My Lancer has a single tube air flow meter and it looks exactly the same as the one above (I'll have to get part number to confirm). It has an external air temp sensor located on the inlet pipe after the turbo, but before the injector unit. I'm interested in how you get on with this as I've had on going issues trying to get my Lancer going properly. Still not figured out after 5+ years of ownership as nobody can get their head around how the systems work. I have some info on the Lancer 2000 Turbo and Cordia Turbo. Let me know if that might help and I can try look stuff up. I think I saw calibration value for the intake temp sensor somewhere, but not sure if it would be the same for Starion.
  2. Someone on this forum long ago told me not to use some Armour All type products as they contain silicon which dries out the vinyl and causes cracks. Not sure how true this is, but from that point on I've been periodically applying Neopol and I haven't had any cracking in the vinyl of my cars since I've had them over the last 7 years or so. Neopol is available from your local supermarket, usually. Neopol All Purpose Creme Polish 300ml | Kitchen, Dining & Household | New World
  3. Scrubb
    best antifreeze
    I've been wanting to run some sort of waterless coolant for years but haven't seen anywhere selling it. I'll be keen to know if someone knows where to get it.
  4. I've had good success with this website: PartSouq Auto Parts Around the World
  5. I'm keen to experiment with casting some car parts or 3d prints but I haven't yet due to cost of materials and not having a vacuum pump. Have you found anywhere in NZ that has reasonable prices for resin?
  6. That mini looks sweet! Well done!
  7. Thanks! I surprised myself with how that turned out, actually lol. I painted it using an airbrush with Tamiya Metallic Orange and 2k urethane clear for the clear coat.
  8. I'm trying to stay interested in doing 1:24 scale models, but the end result seems to be much more appealing than the actual building, but I have several kits to build, so must keep going. Here's a couple pics of my latest build: And here's what I'm currently working on and I cannot wait to have it finished!
  9. This can be done from the router side by setting up reservations in your router settings. You need to know the MAC address of the device and the IP address you want to give it. Most routers allow you to set reservations. This way you can have your devices set to automatically get an IP from your router, and they'll always get the same one. You also don't have to manually configure each device. You can usually also change your DHCP settings in the router to give out more dynamic IP addresses too, if you need more addresses
  10. Haha, yeah! The noise went away when we took out the loose catch can we realised was left rattling around in the engine bay
  11. They look similar to connectors on my Mitsubishi injectors. I think they're some sort of generic Bosch connector from memory. Edit: These, maybe? http://www.nzefi.com/product/bosch-ev1-fuel-injector-connector-compact-clip-version/
  12. Pictures aren't working for me. Are they working for anyone else?
  13. Wanted to come to this, but I had commitments that day Any pics?
  14. Ah, looks like it's 5 inches wide then, according to this? https://www.tyresizecalculator.com/wheels/wheel-markings Sounds teeny tiny?
  15. Manual says wheel size is 5J-13. Couldn't find any markings on the wheels.
