Local Area
Auckland
corrupt's Achievements
Post Fiend (4/5)
Things done since last post: forgot to put rego on hold for the last six months, ouch.
1986 Toyota Mark II JZX71 boso/stance project discussion
corrupt replied to bosozoku_gx71's topic in Project Discussion
Haha this thread is fucking lol, I've trollololed over your car more than enough in person at JZX meets and I actually expected a much harsher response from the os members. Either you're man enough to take all the brunt, or oldschool have calmed down and become more civilised. I remember being around when a dude who thought cheviot turbos were worth a 2k was literally laughed away. Chuck some recent pics up, haven't seen it for a while. -
I have converted my mk5 to an efi fuel setup during my efi conversion. I mounted it all on the platform in the boot just behind the rear seat. With 3 fuel lines(feed/return/overflow) coming through a hole in the floor which I cut above/to the drivers side of the fuel tank. I replaced all the standard plastic fuel line with 5/16 bundy tube so it is up to the task of efi fuel pressure. All of my set up is in the boot apart from the fuel lines. My setup is as follows: Fuel tank feed v Low pressure fuel filter v Holley Blue low pressure pump v Surge tank v VL efi pump v efi fuel filter v fuel rail v Adjustable fuel reg v Back to surge tank v Surge tank overflow into fuel tank return If I remember I will get some photos over the weekend...
Here is my annual update: Decided that before I moved out my last flat that I would give her the once over while I still had a double garage to work in. Fixed the majority of the rust and sealed the usual areas with a coat of por15. Dug out a shit load of suspect looking bog jobs/fixed surface rust beneath and redone. Pulled off the rest of my fibreglassed on front lip (got munted putting car into a trailer once, putting mk5 sport one on instead) Gave her a fresh lick of paint. Turned to shit so sanded/flattened said fresh lick of paint off with 400 to make it look marginally better. Moral of the story - Dont use paint which has been sitting on the shelf for 5 years as it WILL ruin all your hard prep work. Pieced together a shiney intake pipe with old bits of piping Finally got my act together to try get her tuned right with the megasquirt -Replaced original fuel reg with a aftermarket adjustable one with guage -Set fuel pressure lower than it probably was with old fuel reg (running vr4 450cc injectors which are a tad too large while im still NA so set fuel pressure @ 32psi so I could get a decent injector PW) -Changed injector timing to 4 pulses/alternating rather than what was working best before 2 pulses/simulatenous (think i still might try 2 pulses/alternating and raising fuel pressure) -Purchased TunerStudio to make use of their useful built in calculators as a good starting point (VE table and target afr) -After much screwing around and recalibration of the wideband o2 sensor, took her for a drive while running VE analyse live and it seemed to do an awesome job and resulted in a pretty decent afr throughout the range. Things to do: Hook electric fan up to MS Rewire loom through different hole in firewall (doh should have planned this one better) Tidy up interior (my door cards are looking very neglected and the cat ripped up what was left of my carpet) Get wof and put lower springs back in the front Repaint or perhaps vinyl wrap Drive it over summer like a boss
yep genuine, 19x9 and 19x10 unknown offsets 35ish is my guess
New body kit New wheels Empty wallet 13.8@105mph
worthless update, but im gonna pull this out of the garage this weekend. I had a bit of rust fixed last xmas and now pretty much just needs a proper fuel map on the megasquirt...
might be too late.... but i did a write up on the sierra electronic ignition years ago. its on these forums even! //oldschool.co.nz/phpbb/viewtopic.php?f=48&t=5064
Its been a while but its now running with EFI manifold and megasquirt This is all after numerous teething problems such as the ecu going up in smoke after frying the injector driver due to the low impedence vr4 injectors, have remedied that issue now with a injector resistor pack off a honda. Its just NA for now to keep thing simple as im moving house soon and want to be able to drive it there. Pics will follow when I have a bit of time to move it out of the garage into some proper light. Also need to take it for a road tune, pretty interested to see how well the wideband works.
This things so sweet, love how low-key it all looks at this point. I can just imagine how loose this is when its greasy, my 1j is dangerous enough. What are your plans for it body wise? just tucked rims under guards, or are you looking at slapping on some form of body kit?
I dont think they can do eye - eye style shocks, but best to ring and ask. Easy enough getting shorter shocks of that style anyway.
Yep give autolign a call, they are out by sylvia park, carbine road I think? I have used them before and it was roughly $50 per shock.
haha lotto eh, youre not doing the car justice until its manual, i remember the first time i drove mine manual, i had a grin on my face for the whole night. i reckon it was/felt 20% faster and after the initial excitement of it being manual, a much safer car to drive, theres just something about being more directly in control of the engine with a clutch, chopping down gears etc is sweet its mostly all of the reason i didnt end up highflowing the turbo, was so keen to keep the response between gears, laggy would suuuuuuck
convert it to manual man, they turn into completely different cars
Nah nah, its was just a standard rebuild, bar the steel wheel. I had originally told him i wanted to highflow it similar to what you had done, but i decided to just keep things standard for now as it is my daily driven car and I have no intention in upgrading fueling/ecu anytime in the near future. In saying that, now that its steel wheeled I can now safely wind the boost up past 1bar without fear of a ceramic turbo shitting itself, should go mental as with anything over 1bar, already mental enough on standard boost, convert yours to manual and you'll understand
