JR's Achievements
Advanced Member (3/5)
1.2k
I had a similar issue recently, I'm not sure where you are but these guys have quite a good website with pictures of all of their master cylinder. It helped me out. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Index.aspx This is the one I bought, actually looks similar to the one in your link. https://www.butlerautomart.co.nz/Our-Range/Clutch-transmission/Clutch-master-cylinders/Product-Specification-32987886.aspx
Oh true, I just had a look at his profile and it looks like he hasn't been on in a few years. That's a shame, I'd love to catch up with some locals who also have terrible taste in engines/cars.
Thanks @RUNAMUCK I’ll follow him up cheers. No, what’s the TT group? haha, that does sound good… my bank balance doesn’t agree though haha.
After a bit of messing around I've got the flywheel, clutch and master cylinder sorted. I was looking into the different types of sound deadening, Dynamatt seems to be the go to but fuck it's spendy. Just to do the front half of the interior it was going to cost about $450. I went the cheap Chinese route instead. I bought enough to do almost the entire inside of the car and it was $45 including shipping. Time will tell if it's any good, but it seems about right. I pulled the dash and trim parts out from under the bench and gave them a clean up. It was the first time I've seen them in about 16 years. The stored really well. I have had the instrument cluster in at Parrot and son to have a little work done, the main thing was having the tacho modified to suit the 6 cylinder and they fixed a couple of small issues. I've wired the engine up more or less. I'm waiting on the electronic ignition to arrive, I'm going to run some hard fuel lines, install a fuel pump, regulator and make some new brake lines. The drive shaft is being built and should be ready in a week or so. Hopefully not too much longer until she's running. The interior is mint apart from the front seats, they need recovering and probably some new padding. Does anyone have any recommendations for someone in Christchurch? Cheers.
- 7 replies
- 19
JR started following Adoom's 1972 Triumph 2000
Here is a wee update. The fist job was to sort out a couple of issues on the hydraulic clutch setup. I realized that the slave cylinder I had that came with the bellhousing fowls on the headers. After a bit of head scratching and hunting I found another slave cylinder that just fits. I heated the headers then tweaked them out about 15mm to give a bit more clearance, it is still very tight. I still only have about 10mm of clearance. I'll make a heat shield I think. That is the new one, only problem is that the bolt holes don't line up with the holes on the bellhousing. So I milled slots in it. I was going to TIG the bellhousing holes and tap them but I decided not to just incase this new slave cylinder doesn't end up working out. For the master cylinder I welded a backing plate to the fire wall and mounted it in the engine bay between the booster and the header. Tight fit but it works. That picture makes it look much closer to the header than it is. I couldn't have it directly behind the clutch pedal unfortunately, so it's off set from the pedal. I used some steel rod linking them all together and threaded the ends. It's nice and smooth, I'm hopeful it will work well. Engine in for hopefully the final time. I couldn't mount the gearbox as when I went to fit the fly wheel I realized I don't have any flywheel bolts. Doh. ARP ones are on the way. Next I'll start wiring her up and put the dash back together. Cheers guys. P.S. Pro tip... Don't spray a car in jandals. That was taken after 2 showers.
- 7 replies
- 20
Cheers, yeah upgraded valve springs are in. When I was in my teens I cooked one of these engines not long after a rebuild. Oil pump drive had worn out, was a very expensive and time consuming lesson. I've replaced the drive on this one and bought a spare while I was at it haha. Cheers.
I've been chipping away a fair bit lately. I managed to find some radiator suport panels. This was my first time doing any sort of panel work, after a fair bit of tweeking I managed to get them good enough to where I was happy. I also filled in the 2 big holes in the engine bay. Years ago I hacked off the washer bottle mount to make room, luckily I kept the remains of it. I made new ends for it to replace the bits I hacked away. Replaced the battery tray. I did a test fit of the engine to sort a few things out. The main things were the gearbox cross member and where to fit a clutch master cylinder and sorting the exhaust. Not a hell of a lot of room, but it worked out OK. The wee fella helped modify a toyota gearbox cross member. I've just finished painting the engine bay today. It's not going to win any awards, but I'm happy enough with it. I'll start the final reassembly now. I sorted out the flywheel/clutch issue too. The guys who did the engine work (Kennally Cams) did some magic to the fly wheel and machined it to accept shouldered bolts to locate the pressure plate as it's being torqued down. Hopefully this week I'll get the engine in for the last time.
- 7 replies
- 30
Hmmm, shit that's a worry. To me the bellhousing looks fine. Sounds like you have had a bad experience with them? What happened? Mk2 and 3 are the same but MK1 are a fair bit different. I might have to try and find someone locally with a MK2 or 3 and just try to copy theirs. Does anyone have one in Christchurch they wouldn't mind me making some cardboard templates of? A box of beers in it. Cheers, yeah pretty happy with how the engine is looking.
Ohh legend, I've just messaged him. He's basically my neighbor, I'm In Lyttelton. Cheers for that!
Cheers dude. I bought one of these guys panels through palmside a while ago (battery tray). Unfortunately Palmside don't stock the radiator panels. I did look into buying the radiator panel direct from steelpanels.co.uk but it's over 1k nzd and a 3 month wait list. Does anyone know of a front cut? Or a wrecking Capri?
Don't hold back, tell me what you really think haha. Ok, yeah that really sucks as the clutch kit they supplied wasn't exactly cheap. I'm looking into using the clutch plate they supplied that fits the gearbox with the ford pressure plate... Wish me luck.
She goes 100mph just sitting there. Pretty stoked. I picked the engine up a few days ago, the guys at Kennally Cams did a brilliant job. I've just been putting the shiny parts on. The bellhousing and clutch kit arrived from Dellow Conversions. On the whole I'm happy with it. The bellhousing is perfect, but I'm a bit worried about the clutch assembly they supplied and would appreciate any input. They supplied a kit to mate the engine to a w57. Pressure plate, clutch, slave cylinder, bellhousing etc. They modified the pressure plate that they supplied. The original ford pressure plate has 6 bolt holes plus 3 holes for dowels that are on the fly wheel. The one they supplied has 6 holes total. 3 line up with bolt holes and the other 3 have been drilled out by them where the dowels go.. But over sized so the dowels no longer locate the pressure plate. That is one of the holes they drilled out. This is it sitting on the fly wheel. I have just had the engine balanced. My concern is that without the locating dowels (they are useless as the holes are now too big) the 3 bolts alone won't locate the pressure plate exactly in the center necessarily. They guys that built the engine don't think it's a good idea to run as is. What are your guys thoughts? I queried Dellow, and they said yeah, nah, it's sweet. Also, the front cut for the radiator suport panels seems to have fallen through. I think the dude literally died. No answer to calls, txt or email. And the shop (kiwi auto) is chained closed. Cheers for any input! John.
My aliexpress knock off short shifter just arrived today. So far I'm happy with it. Seems well made. The best part is the price $38 plus shipping. I will buy the cube steel bush though. I'm trying to find a housing and shifter shaft part for a rear position shifter like this. If anyone wants to swap, or is selling one hit me up.
Cheers, yeah I think I'll give that a go. Yeah when I saw how flogged out it was I thought it could be a real mission to sort. But I've looked into it and it's actually just a bushing that's fucked. The bushing has an outer steel holder. So the plastic part is gone and it's also then flogged out the outer steel holder, which comes out and is replaceable. There is an outfit (Cube) that sells a different design, it does away with the plastic so its solid steel. I'm assuming it's quite common issue then.
Progress is slowly happening. I managed to find a front cut to get the radiator suports at Kiwi Auto Spares here in CH. I had no idea that they actually have a heap of old cars there. They said it will take them about a month to get around to cutting it up though. In the meantime the guys at Kennally Cams have been getting to working on the engine. It's been balanced, the new pistons and cam are in and just the last of the head work to go. Sorting out a gearbox has been a lot trickier than I thought, I just couldn't find a bellhousing to mate a type 9 up. I had a heap of help from some oldschool G.C.s who offered me a 4speed ford box for free until I could sort a 5 speed out eventually Cheers @dmulally and @Adoom But then I realized I have a W57 thats been sitting in the garage for almost 20 years, in the end thought if I have to get a bellhousing made to suit the type 9 I might as well get one made for the better Toyota box. So, long story short I have a Dellow bellhousing being made to suit the W57 to the V6. I started having a closer look at the Toyota box that's been sitting for decades in my garage, I had never really had a proper look at it. It was sold to me as a good box way back when. Now that I've taken a look, the gear selector bushings are completely worn away... like non existent. I managed to scoop out the remnants of them from under the gear shifter, it seems like it all got caught in the rear of the housing that's separated from the main part of the box (that's what I'm hoping for). The white plastic bushing on the bottom end of the gear stick was non existent too. This is the crap I scooped out. I've opened up the drain plug and as far as I can see there doesn't seem to be any rubbish floating around inside the box. What are everyone's thoughts? Get the box rebuilt to make sure there is no rubbish floating around or go new bushes, a flush and hope for the best? My wallet say hope for the best. Cheers.
- 7 replies
- 15
