al_feinted
    Auckland
1553 profile views
al_feinted's Achievements
Advanced Member
Advanced Member (3/5)
125
  1. Great car raisin, look on the bright side, you didnt find any chicken wire and newspaper in there Id do what tortron said. Once its sealed underneath you may be able to reach in from the boot and get some fish oil on the inside for extra protection.
  2. If a car is deregistered and has a cert for lowering/turbo engine etc, do you need to get a new cert before revinning or after revin, or is the exsisting cert fine?
  3. Hi, to my knowledge TT142/TT140 would be the bolt in solution as would TA61 and TA63 as mentioned above. Corona, Celica and Carina all share the same platform in the T140 & A60 series. Not 100% sure about the SA60 bolting up to the 3T ?? Can you look at one of those online part catalogue websites to compare part numbers/diagrams? The earier model celica and coronas TA45/ TT132 all used steering box so not bolt in.
  4. Ryanfels old gx61 when it had a 1geu started running really shitty and from memory the cold start injector was flooding the engine. Another thing to check... I suspect you will end up having to swap everything efi/electrical sensor related from your 1GEU to the new motor. Start with the easy bits, hopefully it doesnt get too involved. GL.
  5. Sweet rona wags, like many others I learnt to drive in my dads corona wagon TT130 model or something like that. Gutting to see the motor die after the work fixing it up. I wrecked a st141 wagon years ago, sold mostly all the parts off it incl rear door. no spare radiator mine was thrown away too rooted.
  6. That looks like it could be a pain to fold up, could you go to a wrecker to find some parts with a similar profile even if they are from the front door windows, use two and weld them together to get the 1400mm length you need. Compare the thickness of the tailgate glass to the glass of a donor vehicle to quickly check if it could work?
  7. Thanks be4ver, its only because im looking to go overseas im selling, I thought I would never sell it but realistically it barely gets used. Time to let it go. I saw that one from the trademe thread sell for nearly 4.5k last night, stock 1GE/auto but low k's and a tidy example.
  8. I fitted the supersharks in their blue form and took some pics of the suspension at the same time. Took the grande badge off the grill and swapped on a dohc 6 badge from a soarer MZ10. The car will be up for sale soon discuss... http://www.oldschool.co.nz/phpbb/viewtopic.php?f=18&t=14229
