RT's Achievements
Committed (5/5)
7
Today was dyno day to see what difference the kennelly cam and the T5 made, last time it was 245hp@rears and this time it pumped 310hp @ rears still on nasty 91 pump gas.. (actually I drained my motorbike gas before I left so it wasn't even fresh 91 :doubt:L). I was going to be happy with anything over 280@wheels so 310 is a pleasing figure. The cam made such a big difference and I would highly recommend for ANYONE wanting a camshaft to call PK from Kennelly Cams , don't just buy something off the shelf. He really knows what he is doing. http://www.kennellycams.co.nz
Shit.. a year and no update. sorry boes. what have I done.. let me see not long after box swap I broke the speedo cog off the gearbox.. fished around for an hour with a flexi magnet to get the clip out of the hole cos I couldn't be bothered taking engine and box out to fix a speedo cog when the speedo was way out anyway. Ordered a GPS speedo and rev counter from speedhut.com and boogied it up into the original gauge cluster. The GPS speedo is a thing of beauty, keeps perfect speed and you can change gears as much as you want. Also does 1/4 mile times, 0-100 times, trip meter, top speed recording, blah blah, you can even input your existing mileage into it. The rev counter is equally awesome with a 3 stage shift light.
PM replied.. 302 is a natural choice for a capri. sorry for the late reply.. don't come on here often.. holy shit what the hell happened to this site? New look = totally gay ftl
Ok so my capri was originally a manual, then I put a V8 with auto box in it and certified it. now I've changed it back to manual. No cutting anything to put change the auto to manual. I've heard that I can just pay for an adjustment to my cert plate rather than having to re-certify the whole thing?
CHCH - 16 September -Fundraiser and Support for Wayne Martin
RT replied to jtkp61's topic in South Island Region
This is real shit, Wayne is the best (and only to be honest) vehicle certifier in Christchurch. He is the most knowledgeable and helpful person and from my dealings with him for my Capri, he would never 'cut corners.' He does everything by the book in a fair and professional manner. There as obviously a motive for this, to stamp out modified cars in Christchurch. They know if they can cut Wayne out of the picture, it will be basically impossible to get a low volume certification. What someone does 'AFTER' they get a certification is outside of Wayne's control and it's completely unfair to Wayne and to everyone else who is into modifying cars in Christchurch. I will be donating what I can, I hope we can drum up some true oldschool support here! -
flanges yep, makes it possible to fit the engine/box in at once. But everything is a tight fit getting a V8 and T5 into the capri. When the clutch needs doing I'll pull the engine and box out. lol I'm just mad cos I've only just finished putting it back together.
That wouldn't work either, can't drop the box down enough cos the exhaust h-pipe is in the way and can't get access to remove the shifter with the box in the car. Shifter has to be removed to get tail shaft off. Maybe one of these http://www.speedhut.com/custom_gauge_de ... er-971.htm
well that would be options 1 then.. have to pull engine/box. (btw I'm not talking about the speedo gear on the cable, I'm talking about the plastic speedo drive gear inside box)
Ok so after months of work getting engine and T5 in my car, everything is all going awesomely and I'm about to get engine tuned and cert done and enjoy some driving! But now a problem: Speedo was working, then it wasn't working. Checked speedo cable - all good. Checked speedo gear in the T5 Borg 5 speed and not good. Plastic speedo gear seemed to have slipped down the shaft a bit, tried to move it back up with screwdriver and ping, Speedo gear has gone. Here are the options as I see them: 1. Pull out engine and gearbox to fix (really don't want to do this all for a stupid little plastic cog) 2. Try and remove tail shaft from T5 whilst still in car. (most probably impossible as it's a tight fit) 3. Remove gauges and replace factory speedo with a electronic speedo with a GPS sender http://www.autometer.com/media_newsarti ... =3&aid=124 4. Get one of these and forget about it until the engine/box has to come out for some other reason: http://www.trademe.co.nz/motors/car-par ... 780524.htm Looking for any opinions on this.
hmm how about an update.. So I removed the engine / box to change the C4 auto to a T5 manual. Got a world class T5 box with hurst short shifter on it. Also bought a new flywheel and clutch setup. New custom billet Kennelly Cam http://www.kcams.co.nz Pulled engine out. Removed camshaft for a new . Turns out I had a cracked rocker so send a pic to Scorpion Performance in the US and they sent me a new set for free. Last night we setup the pre-load on the new roller rockers: Then we setup the flywheel and clutch onto the engine.. realized we forgot the sandwich plate.. so had to take it off and do it again.. ran out of loc-tite and had to mission to nismos to get some more. Usual backyard garage story. Used a socket and a extension as a clutch alignment tool. Worked a treat. ready to go
Where can I get some for my Ford 5.0 flywheel?
I see.. that isn't going to work then. Capri ones are a single piece Enfords do a new rubber coupling kit I'll just do that I think
It gets better, since the shipping wasn't much more - they send me a complete set of their latest rocker designs. Arrived this morning. Boom.
not sure how the coupling is fitted to the column end. The factory column as a t-section where it mounts to the rubber isolator, you must have to cut that off or something?
Already tried Palmside and they don't sell the rubber ones. Doesn't look like much isolation going on in those Gp4 ones? Is that just a solid connection?
