Everything posted by sentra
All the racing lawnmower forums are dead these days, I’m trying to determine if the crank, cam and lifters on briggs flathead 28 is interchangeable with the 28 ohv motor, all the info online is for flathead- maybe because of their class rules? there is one comment I can find that suggests that it is, if this would be convenient as there is a billet flywheel, crank, cam, rod & piston available for the flathead motor and I have some ohv motors onhand. (The non avs early kind) Trying to end up with a light weight air cooled 500cc vertical shaft motor that will do 5500-6000rpm for my amphibious boat thing, currently using a 200cc and it’s a little underpowered and it makes me nervous turning the pot metal flywheel so fast. I guess the other way is to find out if the 28 flathead is common in nz, Shiloh?? I forgot your username to tag you!!
New beam’s laminated and machined from @Ned’s 3d scans, amazing outcome for such a big surface and “low cost” scanner Realising I don’t have enough talent for structural fiberglass work, talented uncle Neemia from work took over and is doing an excellent job, a layer of glass is over the inside of the hull and the beams bonded in place to be laminated over the top of.
- 19 replies
- 18
@Ned came and scanned the floor to be able to make new beams and a new floor, Also fanboat Brian came over and convinced me to stop being a weaner and cut the last peice of wood out of the back. all the serious misery work is done for now, will make up new beams and floor panels then probably get a friendly boatbuilder to glass them with a chopper gun as it’s not a performance machine.
- 19 replies
- 15
17 years after its last birthday, it’s time for another The floor was dubious the first time around, wood is a terrible product. All wood to be removed this time. Stringers, beams and transom. A very happy @Tumeke helping with the misery is it time for a barra
- 19 replies
- 24
Do they take vband clamps with a wider vee groove? I don’t think the one on my exhaust is correct as it’s sitting up on the shoulder of the flange bit and looks uncomfortable
so cool
The motors from early 90’s but only done a couple of hundred hours/religiously maintained as part of rescue fleet - nothing suggests crud but I will poke further to check What j5 said sounds sensible, I will just crack the stick a bit to break the vacuum and check next time - surprised this didn’t come in up when googling
I made a video of it
Can anyone explain a mystery why on a big old diesel motor if I pull the dipstick out after running it’s dry, but If immediately dip it again it’s full - like magic its like there’s something hydrophobic (oilphobic???) on the stick after running same deal if I shut it down and leave it until the next day, first check it’s dry, second and any subsequent checks it’s full
does anyone know why small vertical shaft engines make so much less power than horizontal engines he same cc do they grind the cams for lawnmower rpms?
please fill it full of french electrical problems joe
Eastcapescapade #6 2022 November 11th, 12th, 13th
sentra replied to johnnyfive's topic in Upper North Island Region
is that a snorkle under your seatpocket tori -
if not john brooks then optibelt carry them in nz also
ive been proactive and prepped too far in advance and now there is enough time to break both bikes. -
cheeers did you take that pic special?
what is the best tool for crimping those narva insulated terminals? i think ive seen a hexagon one that crimps on all sides like a hose crimping machine?
with state of the art electric valves, compression, manifolds etc - how far can the island be moved? the tides coming in.
but i want you to do it
A 2T will do 15k+rpm, why haven’t we seen gearboxless cars that do huge rpm’s and slide the efficiency band around with modern variable everything technology? Is it a big-cam conspiracy?
can you guys hassle me to organise a chain & sprocket for ct and also a piston for sue -
You riding from Auckland? -
woke up in a panic this morning from a dream I was in j5’s paddock at the start of this trying to fit the engine in while everyone roared off tonight job is to fit the engine then -
bloody hell fletch your going to lose your licence/crash into the paetiki bakery like @Testament
