Get it done
Gender
Male
Local Area
Wellington
Get it done's Achievements
Post Fiend (4/5)
1.4k
Get it done replied to Roman's topic in Tech Talk
Be careful that the glycol in the anti freeze does not expand the seal and cause it to pop out etc -
Also made a wind chime to annoy the missus. made from an old clutch disk , flutes are are from and old intake manifold project and the bell knocky thing in the middle is a yanmar digger piston . I will balance it a bit better later.
- 1268 replies
- 20
- 1268 replies
We have had similar issues , couple of things to try and check are the guazes in the first banjo fitting at the lift pump for obstructions, also check the fittings on the filters between the tank and pump. might pay to chuck a clear hose between the tank and pump to check for air bubbles. the lift pumps can suck in air and I’ve found small pieces of wood stuck under the diaphragm allowing fuel to flow back to tank. check the tank breather is clear. Make sure the battery is fully charged to ensure the solinoid is seeing full voltage . nice project, it’s going to be a beast .
What has been said , the welding process will shrink the plug , an bar will allow you to turn it . just make sure you let it cool first -
My boy loves checking the mail box every day so I surprised him with this. he thinks the coolest part it taking letters out of the arse. should rust up good.
- 1268 replies
- 20
Private msg me
Get it done replied to KKtrips's topic in Lower North Island Region
Are you guys open to peeps turning up with non Oldschool cars etc ? have been asked by a coupe of interested parties recently. -
I bought a l28 years ago and this was the problem . after installation of taller valve caps it was all good . The cam had a really aggressive grind and was a lot smaller. my 2c
Convert a aircon pump to use as a compressor and use a fire extinguisher as a air tank , about a 1kg is compact enough. works mint in the winch truck. -
Does anyone have plans for a home built car rotisserie please? -
Transpecs or Bnt can get them , but talk to the brake Certifier guys or you will be talking to a brick wall. they come standard on there abs and ebs kits. -
Cm trailers do a side mount brake line Master cylinder that will eliminate 90% of crushed line during loading and unloading, especially relevant when using a mini digger as the diper arm with clean up bucket attached sits on the drawbar.
Old trailer screw compressors are a viable option imo. they usually rust the trailer body rather quickly compared to the unit hours. so you may end up with a low houred unit with a rusted chassis for minimal outlay . I did this and scored a unit with 400 hrs for 700 bucks. Keep it for about 8 yrs then put it back on home built traile and sold for 7 k , then bought a cabinet screw compressor just for the quietness. a screw should be your end goal , once you screw there’s no going back.
