Lord Gruntfuttock last won the day on January 20
Lord Gruntfuttock had the most liked content!
Gender
Male
Interests
Driving the wife mad by buying projects and tinkering in the shed at 5am...
Local Area
Southland
Lord Gruntfuttock's Achievements
Committed (5/5)
39.7k
Just wanna say it's good to see the ongoing updates on your project thread. Good to see the issues, minor tweaks and improvements (and foibles) involved in owning an old car. Nice to see it being used too...
So for a standard bore GN (57mm) and CT90 stroke of 45.6mm that's around 116cc of hybrid power...
Ali Carb And think I bought shocks on ebay, around 335mm and 10/12mm mount holes, around $60 US plus post. Prob cheaper options
Fuck yes, keep the 90, they're great little chuffers when you get them sorted. I'd clean things up, hone, piston and rings if necessary and use. I re-kitted the carb but never had it running right so put china carb on it that goes ok. They need over 6V to fire and there's no drop-in electronic ignition available sadly, but I did the Brass monkey (~ 280kms one way) no bother on OG points, and have done a couple of trail rides where it went places other bikes wouldn't. I toyed with changing sprockets but factory ones work ok if you're not after something that will do 100kph (people chasing that end up with not enough torque to push it that high anyway). if you're just using it off-road you could prob sell the aux tank and exhaust for quite a bit of dollarydoos, chuck a cheap pipe on it and profit. Think I replaced rear shocks on mine with Ali specials, as OG too soft for my svelte frame... this will ruin other bikes for you. CT90 the world...
1964 MG B Roadster Discussion.
Lord Gruntfuttock replied to MichaelJFox's topic in Project Discussion
Cool colour, should be easy engine to work on. There will be heeeaaaps of information on MGBarryforums... -
Chch Bbq/working bee. Sun4th Feb.
Lord Gruntfuttock replied to MightyJoe's topic in South Island Region
dreamy... -
LGs 1975 Ironhead Café Racer tidy up
Lord Gruntfuttock replied to Lord Gruntfuttock's topic in Two Wheels
Yep. Pump under the engine, been on HD forums and you can machine one side of the pump housing and install a seal, but it's an engine out job so it can wait. I think I'll check if it pumps itself out when running by checking oil tank level after sitting first. -
So after falling for a parts scam, I wrote it off to experience and looked at ordering gear from eBay, from a seller I'd used before. Parts are pretty cheap but postage can be a killer. Before xmas I decided to see if removing 3 springs would be a viable interim option. Whipped out the clutch tool, but disappointingly the primary case was again overfull of oil. I'd seated the pump check ball, replaced the engine main seal, fitted a generator oil slinger and installed the starter solenoid rubber boot that was missing, so a bit baffling. Someone here suggested it may be a worn oil pump shaft, I dunno...? I pulled 3 of the 6 springs and buttoned things up again, was quietly confident until this happened... Arse. Completely my own fault, was rushing to get a ride in to test things and instead of using a small spanner I'd wailed on these 1/4" nuts with a socket, just missed the point when it snugged up to the spacer, so bent it and snapped a stud... I looked at machining up a new stud and spacers, but decided to add a new basket and spacers to my spring order, parked the bike, and went camping with the kids over xmas/new years. Was a good break, and I got to wear my new clutch spring/sunglasses... Anyway, parts arrived yesterday... And was nice installing new bits... Quick ride around the section showed a good improvement, clutch seemed to operate cleanly, and less effort required at the lever. Won't know till I give her a good run through town, but encouraging... -
EA Sports Old School fatarse rally car
Lord Gruntfuttock replied to Lord Gruntfuttock's topic in Other Projects
Night stage lamps test fit... And coming together... -
Oh it's very red... Actually truck paint, from a local transport company, hard as fuck, painter couldn't buff it, will be interesting to see how it goes... Cockpit pic... And I'd made a brew for the crew some time ago, got bewbs...- 19 replies
Some random progress pics I found on my phone... -
Best bits of both bodies put together and sanded for paint. A really good shell in the end, straight and very little corrosion.. And done... Taking it back to workshop tonight to start putting things on properly, which is exciting. Had to keep reminding ourselves it was a rally car during paint prep. Southland rally in June is first race target, will be road legal so hope to get it running way before then for shakedown, should be fun...- 19 replies
