Rupertg
    Outside NZ
442 profile views
Rupertg's Achievements
Advanced Member
Advanced Member (3/5)
828
  1. Regarding pimp my disability... Could be a great interim/future 2 stroke upgrade...
  2. Is that barbed wire on your wall? I presume that is not the neighbour you are going to effort for.
  3. Some small tips: If you are going to use fibreglass you don't need concrete mix, just sand and cement. So it makes it a lot easier to work... If you add a fine bead of silicone to your internal corners in your form you will get chamfered edges on your finished piece and no seepage from the mould. You can lightly sand the finished product if it has any high spots, without aggregate you won't get that ground concrete look, but care is required to not expose the fibres.
  4. So regal on its rug now too. Certainly brings all the reds together
  5. When the baby needs a cot and all you can find is a couple sheets of ply, a cad package and a friend with a cnc router...
  6. When the impending baby needs a rocker.... and all you can find is some solid bar and hardwood offcuts
  7. Hey. Really like where this is going. I have one awaiting some work. But am unsure how to get it sitting right. The white one you purchased looks to be sitting a fair bit lower than standard. Can I ask what has been used in the front end?
