RevDWC
  • Gender
    Male
  • Interests
    Motorbikes, RC cars, planes and quadcopters, my Lada.
    BOP/Central
638 profile views
RevDWC's Achievements
Advanced Member
Advanced Member (3/5)
72
  1. The socket you want for the crank nut is 38mm, but 1.5" will work well enough being 38.1mm
  2. They do an honest job of keeping the rims off the ground, but little else.
  3. https://ladapower.com/catalog/niva-1600/heating/lada-niva-heater-valve-tap-ceramic-detail
  4. Same as a Lada then. Thanks for the idea. Running them across looks far better than any ideas I've had.
  5. +1 for ceramic heater tap. Has been set and forget fix, except for me not properly clamping the cable. Does Uterus also have the up and down 50mm offset seat mounts? It looks like some square tube poking out under the seats.
  6. Do you know if the mounting on the Niva diff is the same as the sedan one?
  7. This may be relevant to your interests, Tamiya are releasing an RC Gyro-ish vehicle soon. https://www.tamiyaclub.com/forum/index.php?/topic/83703-tamiya-honda-gyro/
  8. First thoughts on engine swaps is to consider that standard you have the steering box, starter motor, brakes, and both manifolds all jammed next to one another. Seen pics of one in UK with SR20 which tilts away from that space and exhaust on the other side. There is also one with CA18 build on UK Lada forum.
  9. Great find. So stoked to see someone found a 2102, and bringing back to life. Far to cool to let rot away. I'll also vouch for Ladapower. Lord knows how much of my money Pavel has taken... Also, avoid Ladaway.com like the plague. I had one order come through fine, but my next one never left the shop and I had to go through paypal to get my money back. This is not uncommon according to NZ Lada facebook group.
  10. Disconnecting the GPS on one was pretty much my next thought. A sorry and unloved GN there at the moment. That, or call it a training exercise.
  11. Blardy brilliant idea. Shouldn't have sold that last postie bike I had.
  12. Functionally they're very similar and both are designed to be used with the same software, TunerStudio. If you're happy to assemble the board yourself they both look like a similar amount of work. There is a larger, more established community for MS, and looking through the forums, someone has probably done something within spitting distance of what you want. Speeduino say they are still in development stages, but the FB group and forum are great for resolving problems and getting you going. I chose Speeduino because it ticks a few boxes for me, and the money I saved up front can offset things like new temp sensors, an SLC Free kit, and buying the wrong damn manifold.
  13. Have mine assembled and flashed, with Bluetooth configured, but not on motor yet. That part was easy, went smoothly. Have a look at the FB group, they're a helpful bunch.
