Bluebear01
Bluebear01 last won the day on July 8 2023
Bluebear01 had the most liked content!
About Bluebear01
  • Birthday 05/30/1987
  • Gender
    Male
    Christchurch
1565 profile views
Bluebear01's Achievements
Advanced Member
Advanced Member (3/5)
1.4k
  1. Thanks man. Being young and broke is just an opportunity to learn a tonne if you’re working on your own car! I’m in Chch, I’ll flick you a dm and you can have a closer look if you like.
  2. After all that the wedding went without any issues. We covered about 50 miles in total that day, running around for photos etc. At the end of the day I parked her up at the reception and collected many Barry's, all eager to tell me their Austin stories and lamenting that they ever got rid of theirs. Luckily this Austin's previous Barry had the forethought to not throw her away.
  3. Finally, now she was mechanically reliable again (for now) it was time to focus on the paint. After a few evenings buffing all the panels, running steel wool over the chrome and waxing it all for the first time in probably 50 years it came up really good! Better than I'd hoped to be honest. And most importantly the view from the drivers seat was restored to the best it has ever been.
  4. The last issues in the drive line were the driveshaft and the torque tube support bush. The driveshaft UJ's were out of phase which was probably not helping with the "high" speed vibrations. Easy enough to line them up. The bush takes the full load of rear diff twist on take off, so it's no surprise it had collapsed with all that clutch shudder. New bush cut down to size and fitted means it's now running way better and is super smooth on take off again!
  5. The input seal on the box is a scroll seal, and a pretty worn one at that. The female input shaft is capped with a welch plug which is also letting oil out along the splines and flicking through the lining. It was a pretty easy job to lathe out the nose to accept a modern lip seal, and for the shaft & cleaned it right out and made a plug of RTV in the end to seal it up. Gearbox went back in and tested great! Before I removed it I was able to simulate the shudder on take off by releasing the clutch very slightly and holding resistance on the output flange with the driveshaft off. It had a steady pulse that is now completely gone.
  6. So me and my boy wipped out the floor and removed the gearbox. It's super easy to work on this thing! Almost like a model car. The clutch was covered in oil and the clutch fingers were badly worn. The clutch lining was new however and not buckled, so I used a heat gun and plenty of break clean to draw out the oil till it was nice and dry. Then I went ahead & replaced the pressure plate fingers, giving them a few adjustments to make them sit at the same height. The oil in the clutch was gear oil, so even thought the engine is leaking a heap I focused on getting the gearbox front seal dry.
  7. It's had a nasty shudder on take off for a while now. I'd been driving around the problem thinking it must be a clutch issue and I'll sort it after the wedding. On the way to work however it decided to sudenly loose almost all drive! I managed to limp home and after a quick look figured I'd broken an axle. On closer inspection the rear hub had fractured clean in half. It looks like the wheel bearing had walked off a fraction, loading up the hub until it gave up. Luckily it happened now and not on the wedding day! My boss is into his Austins himself and came to the rescue with another hub. After replacing and securing the wheel bearing, and closely inspecting the other side we had drive again. I now thought it might be best if I go through the whole drive line & get rid of that shudder to try and reduce the chances of another issue.
  8. Next job was sorting the paint. The view over the bonnet has been getting pretty sad, the paint has been coming off in sheets! The rest of the paint seems to be ok but it has oxidized quite badly and needs to be cut back. So bonnet off, repaint the top and flick some paint onto the scuttle to help it blend in. Now the challenge will be buffing the old paint to hopefully match the new! But before I could get to that stage she had another mechanical disaster...
  9. I had a mate request the Austin for a wedding recently, what an honor! It was also a really good excuse to sort out the growing list of needed repairs. First up was the ignition coil. The old Lucas sports coil had failed a while ago but I love the look! so I carefully gutted it and managed to fit a modern coil inside quite nicely. After doing that and fitting some NOS points the ignition system seems to finally be reliable. For some reason the new "Lucas" points were only lasting maybe 200 miles before burning out.
  10. While that's going on a work colleague has tidied up the right rear wheel arch and flicked some silver over the boot and rear corner. I took this opportunity to fill the trim badge holes. I'm not sure what I'll put back there yet but I've always felt the factory setup is very busy, with "SuperSaloon" "Toyota" "Crown" and "2.8" all jammed in there. Once the rear doors are done we'll flick some paint up both sides to blend it a bit, and perhaps touch up the roof where the clear is coming off. I'd like to strip it back and do a proper job one day but I know I'd probably end up with the car off the road for years.
  11. Bumpers off completes the bogan look! I kind of knew the bumper bars had a bit of rust on them, but man the front was bad! It's been holding moisture between the foam and the steel, pitting it badly and completely rotting away the clamping brackets. I've had the bumper bars blasted and gone and welded up the holes in the front one, next will be a bit of epoxy and making up some new brackets to put the skins on securely.
  12. It's been a while since I've shown the Crown any love, but we have put 20,000km on it since the motor swap. It hit the 400,000km mark the other day! I stopped for a pic at the exact spot it clocked over. Mechanically its been going like a champ, but the rust has been creeping up on me. Keen eyed viewers may notice the black boot, courtesy of @JustHarry. He's been helping me out with some relatively rust free panels from a decent donor car. The boot lower lip was gone and both back doors have some issues. The left rear is the worst with some big holes hiding behind the trim! Time to stop ignoring it I think. I've also got to clean up the right rear panel which has been in primer since I welded in some new metal 2 years ago, and the bumpers need a respray also.
  13. Probably a better question would be how much power does an Austin 7 make?
  14. Congrats on the purchase! I've done a quick scan of the charging system section & the radio section. No info regarding speaker removal but i can run you through that if you like, just PM me. I am keen to get the whole lot into PDF, when that happens it will be up here. For now here's a link to the 2 sections: https://drive.google.com/file/d/1fzJmHisp1K75IAeEkB7hEhEP93Ja0T7T/view?usp=sharing
  15. Man, I might need to get one of those! I wouldn’t have guessed half of them...
