Everything posted by M M
Where might I run into you if I go for a Burger that day? Been away for a while so don't know which location it is now.
Auckland CHRISTMAS Monthly Meet - Wednseday 13th December
M M replied to Threeonthetree's topic in Upper North Island Region
In true oldschool fashion we ended up helping tow my friend's Rota home which was on the way to the meet. By the end of the escapade we had 8-9 cars on the side of the road as people were pulling up to see what all these cars were doing. Almost ended up bigger than the oldschool meet, ha! -
Auckland Monthly Meet - Wednesday 22nd November
See yous there. -
Chris's 1987 MKII golf eurocup racer car with added moss
M M replied to yoeddynz's topic in Project Discussion
Good work man. Did you test drive it at all? -
I won't make it to this. Leg won't be out of the cast in time.
I can't commit 100% yet but I am interested.
Auckland Monthly Meet - 21st June 2017
I'll be there. -
Auckland OS Cruise - Sunday 30th April - Hamilton
Unfortunately I'm out as well.- 78 replies
- swap meet
- midnight upholstery
(and 3 more)
Tagged with:
I'll be coming along.- 78 replies
- swap meet
(and 3 more)
Tagged with:
Auckland Monthly Meet - Wednesday 22nd March
M M replied to Shakotom's topic in Upper North Island Region
I was exactly laughing at that as I was uploading it. I was intentionally avoiding my car incase they asked me what was under the bonnet. Hahaha. -
Some of mine. Easily the worst of the lot and mostly just of the BMWs. https://www.flickr.com/photos/98811558@N08/albums/72157679763374511 Thanks to the others for the decent photos. Was a good meet. -
Will be there as usual. -
Auckland Monthly Meat - WEDNESDAY 15 FEBRUARY
I'll be there. -
I agree with this, though I've seen maybe one or two kind of pull it off. The problem is the Mk2 has a big recess for the bumpers where as on the Mk1 the bumpers sit in front of the body. So when you remove them it doesn't look like anything is missing.
Tomica93 1987 Mitsubishi Galant 2.0Turbo DOHC RalliArt version
M M replied to Tomica93's topic in Project Discussion
Haha dobro. Ajde onda ajde. -
Not sure about the laws on 2k, I have sprayed it at home but I would imagine it would be frowned upon as it is apparently very bad for you and you shouldn't even let it touch you skin. That said I am still alive and functioning, but for how long, I can't say. However I was out of breath for a couple of days afterwards, which I didn't quite realise the extent of until I went to training the next day and almost passed out. I was spraying outside with a mask, so make sure you get a very good mask. Single pack should be fine as long as it doesn't contact fuel as fuel eats it quick, so be careful when filling the car up. I've always felt more comfortable spraying a clear even if over a gloss paint just for protection if nothing else. But you can go just single stage if you want.
On a Mk2 it will be an issue because the front bumper is also what the bolts bolt into that support the front engine mount. So be aware you are going to have to find a solution for that, be it cutting the bumper brackets off and bolting them up or whatever.
Bas lepo izgleda. Svaka cast. Koliko konja mislis da ce napravi? -
Auckland Monthly Meet - Wednesday the 25th of January
Couple of quick ones I took.- 16 replies
- 9
I am quite disappointed to read this. That was one of their best burgers. Will be there tonight.- 16 replies
Dobro dosli Tomica. Bas ti dobar auto, cu da pratim tvoj rad na njemu. -
I can help you out if there's no one else. I'm staying in Panmure. Send me a PM.
Just some quick updated photos of the interior.
After months of the car sitting and months of me being away, on Sunday I finally managed to find the issue. The coil negative wire (which goes to the ecu, the ecu grounds it to create spark) joins up and splits of at one point to go to the ecu and to the diagnostic connector. There is a ground wire from factory at the split off, grounding the coil. So this means the coil is constantly grounded, and was causing a short. I have no idea why it's done like this and how the car was running before, but as soon as we cut the wire the car fired right up. I checked my other wiring harness and it had the same thing. And now with my new ECU, everything is working including the fuel pump relay and ICV. Even fixed the slight miss it had. Drove the car home on Sunday night, yesterday afternoon the v-belt for the waterpump and alternator snapped. Luckily I noticed something was going on and pulled into a side street. Opened the hood to find the snapped belt (which looked to have also flipped beforehand) sitting there. So called up a friend who arranged one to get to me and I changed it then and there. While waiting I took the opportunity to take some new photos. Should have some more updates for this car coming up soon.
AP also do a normal shock and spring setup for 40/30 and 60/40 which is why I suggested them. It's a shame they are such a pain about coilovers in NZ but what can you do. PM replied to.
