johnny.race's Achievements
Post Fiend (4/5)
1.5k
@tortron Thanks man, excellent clip. Ta.
It's been done a million times but do you think I can get a concise answer of the way it is accomplished? Fuck me! Oh yeah, there is the fact I forget shit easy, haha. But is there anyone that can provide me clear advice on how to go about doing it please. Is it just a special flex plate or something ... my existing starter would still work with it et al. Help. Ta.
Oof! Haha! oh well. It looked to be a nice bit of kit. Flex? Maybe something cobbled up using double shear bracketry if I'm reading it right. But yeah, good to know bro. Cheers.
I got sent these from a dude that imported a handbrake kit from Aus. I mentioned it above i think. It's at the different end than you're talking about carrying out the mod but still. You can figure out which way is up in the pics - I had to. There is a bit of work in it. He paid something like 1K he reckoned. Well worth it I thought but everyone's mileage differs.
Yep, I've seen the Trojan ones for under $125NZD but you might be getting less caliper, I dunno. Another place to look possibly are cart brakes. I've fucked around before doing brake conversions and by far the biggest challenge is matching rotors to calipers in terms of wheel stud PCD, diameter, back space ect. Considerations will be different in what you're mucking around doing though I'd say.
I reckon you need to look at those Trojan mechanical ones more closely. The ones @Transom described above are essentially what they are. I know what they look like and I've seen a pic of a setup being sold out of Aus (I think) for the rear of a transfer case on a r151f. It used a caliper that looked similar to the Trojan. The proof of the pudding will be the holding test that's undertaken on a 1:5 gradient.
Just my observation ... one challenge when fucking around with disc rotors and calipers that didn't come matched from the factory is compatibility. Things like the available gap width a caliper features ... the caliper mounting bolt holes in the wrong place ... the exit direction of the cable pointing at something/wrong way ect. Just some of the arse biters you can encounter. Question; what's wrong with a mechanical Trojan style caliper that makes you think a certifyer would reject it? They are good enuff for road legal trailer duty. Tell. Have you spoken to one of them and he's knocked the use of a Trojan back?
I've never seen bearings in track rollers. Are those the bottom ones or the top? Most shops will swap them over/out. The only type I've seen apart are CAT and they had a big arsed pin that ran in a bigger arsed bushing. Everything floated in oil. Once one of those go it's mates need to be looked at closely. An undercarriage lives in one of the most abusive environs known to man. Dozers more than diggers but they pretty much operate all in the same way. Leaving machines in wet area's/under water is asking for trouble in the undercarriage department. Ching ching ching!
Mate, I've never had anything to do with fitting a Truetrac into Hilux housing. I'd expect it to be bolt in with nothing special though. If I was doing it, I'd spend an extra $50 and go with the solid pinion spacer too. Even the good/tight OEM Hilux ones you come across are no match for good aftermarket offerings when it comes to lock up. They do remain popular though. I'm selling that 3.58 LSD on TM at the moment. It actually sold today - get paid for/uplifted tomorrow. Late model 3 point something :1 LSD's are always worth reasonable money. A grand for a good one is a good deal. They can go for alot more.
What he said ^ Near any rear loaded Salisbury type differential needs to be spread to fit those preload shims in without damaging them. You'll need to use a spreader in conjunction with an accurate DTI and work to spec or you run the risk of stretching the housing and it'll never preload right afterwards. It'll be fucked.
Electronic/electric actuated handbraked rear calipers.
johnny.race replied to johnny.race's topic in Tech Talk
Thanks for this. I like these early corolla calipers but they are not that easy to come by anymore, aye? I've got ae92's, the ones's you're talking about and a couple of others I've collected over time. My experience is this sorta stuff dried up in the wreckers decade(s) ago. I've got an adaption that fits the later zre152 corolla type but they are pretty small, lol! They sell though. But yeah, cheers for the input bro, appreciated. -
Fuck, these are brakes we're talking about - how do cunts think they're going to get away with that sorta shit (or even do it) lol, gawd. -
Did some more r&d on the mk5 to Hilux option. I actually can't see this working with a 15" rim on/in a live axle application. The live axle's design prevents placement of the caliper in a position like that would be found on the bum of a FWD vehicle. This prevents the caliper from working within the confines of a 15" rim. A larger diameter rim could be made to work depending on if a workable rotor could be identified. See that cutaway rim in the pic's I use to check clearance? Clever aye? It was cut down on my rim widener I made out of scrap a few years back. Niice clean job! I know you cunts like this sorta stuff! Chur. -
Do you know what is the common dia of rim usually used on VW's? I've never had anything to do with near most all 4cyl sedans/hatches - fucking cars bro. I lived under a rock and had pickups and the older stuff all my life. -
This is a s4/s5 caliper on a Hilux diff using the 273mm OEM style rotor. It fits a 15" rim with a bit of room to spare. This a an rx8 caliper mocked up on the s4/s5 OEM style rotor. As can be seen it won't work due to the shape of the bracket. I have not tried an OEM rx8 rotor as it's large diameter precludes use with a 15" diameter rim in any case. The caliper fits an OEM style s6 rotor but the combo will not work with a 15" rim either. I've been spending a bit of time in several disc brake rotor data bases looking for options. The s6 rotor might be able to made to work with the rx8 caliper with some diameter reduction but I'd like to avoid having to trim anything unless absolutely necessary. The s6 rotor is OEM 294mm in diameter. I'm guessing something around 285mm dia might work. Fun and games. I put you wrong re all of the brake adaptions I sell working with 15" rims. The brackets I sell will allow the smaller types of calipers I cater for (sp20, zre152, u13) to work with 14" rims. That's current but I might have to revise this going forward with any new design packages that will allow use of later (TBA) calipers and stick to 15" rims. The pic above shows the s13 rotor (258mm dia) I typically use for most of the smaller fitments. Sitting on it is a VW golf mk5 caliper. Clearly not going to work for two reasons - rotors too small in diameter and mounting points fouling housing. They are quite deep/tall there aye? There might be a balance with a rotor in the mid 270's - 280's and it still being able to fit with a 15" rim. I might check things out.
