Jydnz
New Members
    Auckland
Jydnz's Achievements
Newbie
Newbie (1/5)
0
  1. https://imgur.com/a/OHSFo Hi Cletus, Here's a photo of the current set up. Basically 25mm blocks mounted to the original gearbox mounts on the transmission tunnel. This allows the original mount to be moved back the 70mm and lowered 25mm.
  2. Hi guys, I have a mk2 escort fitted with a 5 speed type 9, current gearbox mount is via the original mount using spacer blocks to move it 70mm rewards. However, as I uderstand it it won't meet cert specs. Can anyone advise of how what they have done to meet the cert requirements?
  3. Hi Ben, I'm running a 1600, type 9 5 speed using a standard automatic two piece driveshaft with u joints on the centre joint to a 3.54 diff. No problems. Should be fine with your original one.
