Sunbeam last won the day on January 22
Sunbeam had the most liked content!
Gender
Male
Local Area
Christchurch
1876 profile views
Sunbeam's Achievements
Post Fiend (4/5)
3.4k
Snap! Have been dreaming of jamming one in the Fiat 1500..
Toyota wreckers are thieves especially van/prado/hilux ones. Buy every single wreck at top dollar, corner market, print money. Around here anyway. Good luck
zach_munce started following Sunbeam
What qualifies as cheap for one of these smurfs?
I keep seeing Max peed in his grods. Is that a euphemism for undies?
You sick fool. Respect.
Try acetone with the atf. Otherwise take the crank out and bash the pistons with a steel drift. Wood absorbs too much power from the hammer. Sounds brutal, but the pistons and bores are already rooted anyway at this point. It’s a tractor engine so the marks should bore out for new oversized pistons with meat to spare. I had to use the agro method on a Fiat block to get a piston out. Moved pretty quick once the wooden drift was abandoned and didn’t even break a ring in the end.
Been driving around some more. 2200-2800 rpm is punishing to cruise at. Transitioning through this band is fine and generally it makes bad-ass old car tunes. The rear muffler is a straight through bullet style and this needs to change, I think. I have a new problem with clearance though. The exhaust isn’t banging the floor anymore but now the rear axle housing is banging on the inverted U section. I think I need to ditch the slip joints and weld flanges in instead. This will give me some more wiggle room to play with angles before welding the flanges on. Also I may investigate adding another leaf or part leaf to the rear springs. They are so soft I can make the diff housing touch the bump stops (and exhaust)by pressing down firmly on the boot! Increasing ride height is not an option. Servo pic: 8.8 l/100km on this one. I was expecting 10-11 so call me pleasantly surprised.
- 125 replies
- 16
I can confirm BMW M57 is the shiz. Bone stock is 220hp and 500nm. Almost zero issues with mine in an old X5 with 375,000km. A starter motor and one injector in it’s whole life. I would shudder at swapping it into something else though as they are very electrical, which is not my jam at all. Land Rover peeps are routinely doing it in the UK though.
Yes, 4.5mm is too close. It bangs the floor vigorously when traversing bumps. So I have undone everything again and extended the hook eyes I fabricated for the rubber straps and meddled with some angles and I now have about 10mm. Also, no leaks. Also also it might be a smidge loud. I know, I know but I’m closer to 50 than 40 nowadays and I have enough hearing loss from hundreds of hours in a Cessna 206. Don’t need to be more deaf.
- 125 replies
I personally don’t like doing this on slip joints but beggars can’t be choosers. Also I have new rubber hangers so I thought I’d accelerate the stretching process. Yes, that’s an old battery..
I have gotten as far as I can go with what I have. I’m very happy with the downpipe I bought, the fit is perfect. All the other joints are aligned now, but this leaves the tailpipe exiting at a 5 degree angle. This will be unfixable without tweaking some bends in the tubing. The lowest hanging part has 125mm ground clearance and it’s close to the rear axle so I’m happy with that. I also haven’t been able to avoid a very tight gap with the rear passenger footwell pressing in the floor. I have 4.5mm… is this too tight? Also, every slip joint has a tiny leak!! I’ve run the engine and it sounds quite stout, a bit more bass but still with all the twinky rasp.
- 125 replies
Did a bit more today between farm chores and ferrying kids around (to be fair it was for dirt drift karting which I enjoyed as much or more than the kids). First job was to grind off the bottom tacks so I could tweak the end of the pipe down a bit . Then it was time to trim and hang the rest. This took a few goes. Main pipe section is ok Over the diff is good: The rear “muffler” hangs pretty good too, but could do with hanging a few mm lower which is just a small adjustment on the clamp It’s the bit where the front pipe should slip into the first muffler that needs a tweak: It surprises me how much just increasing the diameter of the pipe affects ground clearance. I have 105mm under the front of the first muffler. This is now the lowest point on the car. Also, the hand brake cable is quite close to the pipe- the bare steel bit, not the rubber sheath which will limit my ability to lift the muffler for more ground clearance. Is there a minimum clearance for cables that I need to be cognisant of for WOFs?
Flushed with the glow of success from obtaining legality for the first time in 15 years, I am acutely aware that there is more to do. My exhaust downpipe arrived. It came with an inch and 3/4 outlet and I need to make it 2. Mark: Chop. No going back… Tack. Beer.
- 125 replies
Sunbeam replied to yoeddynz's topic in Project Discussion
Got told about the plain water thing by my mate who’s much more experienced than me. I would have done the same thing as you did otherwise. Shit that engine sounds good!
