nnzclassiccarnut
    Christchurch
nnzclassiccarnut's Achievements
Advanced Member
Advanced Member (3/5)
28
  1. If the pump had decent flow (test by partially obstructing the end) then the issue is the with a loss of motor speed, Some of the motors are brushless but some have brushes, They can wear and basically make the motor gutless.
  2. Those holes actually line up nicely with the drivers door being replaced, It's had a hit in the side and they punched the holes to push the outer sill out, Check for filler in the sill and you will see what i mean, spmeone did the same with my 850 Coupe but on the back upper corner.
  3. It's good to see my bits going to a good home
  4. That does look a lot better than the shell you got from me, Good to see the bits going to a good home.
  5. Talk to rich at Premium Tyres, Dyers road, he runs a MK2 escort sport and knows what works and what doesn't
