ajg193
ajg193 last won the day on November 12 2019
ajg193 had the most liked content!
About ajg193
  • Birthday 04/28/1994
  • Gender
    Not Telling
    Christchurch
3457 profile views
ajg193's Achievements
Committed (5/5)
13.7k
  1. My brother had a GTI as his first car, must have been nearly 25 years ago. He crashed it on the harbour bridge once Another time he shot a rod out the block doing 180 on a back road After that he replaced it with a 4WD turbo familia, he paid $6000 at the time. No idea if that was a lot of money or not back then. That was a fun car to ride in
  2. Jane says we can do it. @igorI expect to see you there, you are also welcome to crash at our place on either side of the event, we have both a room and a shack on offer
  3. I recognise those storage units, they're directly across the road from where I work in Ferrymead. One of them caught fire a month ago /Ling
  4. You'd think in this day and age the computer would do it all for you. I expect if they tried to give it a 12 month WoF the computer would throw a fit
  5. What's the go with getting a wof 1-2 weeks early these days? Twice in a row now I have gotten 6 months from inspection date instead of 6 months from original expiry date.
  6. My steam converted briggs still had the plastic gear and I beefed up the valve seat pressure to over 100 PSI, surprising what those parts can handle
  7. Briggs and Stratton camshafts have nylon lobes that are injection molded directly onto the shaft and they never seem to fail
  8. Shrink fits are legit. About 4 or 5 years ago I had to design an extrusion container for making magnesium rods, the container needed to be made of multiple shells of high strength (H13) steel that are shrink fitted together to get enough strength. The shrink fit was used to put something like 600 MPa of compressive stress on the inner liner, giving almost 2000 MPa of pressing capacity. I think it was something like a 0.15mm interference on about a 53 mm diameter sleeve, required temperature difference was about 250 or 300C to get it to all fit together. Was quite stressful as the liner was about 150mm long and had a nitrided surface so any lathe tooling would just bounce right off if it grabbed and needed to be redone.
  9. Do those plates have a sanded surface on the letters? I currently have the mill set up for flycutting plates - I can quickly skim a tiny amount off the top to get original finish back if you want
  10. My brother got his ranger diff done by some outfit in drury a few years back, seems happy with the result.
  11. Here I was thinking that a swaybar link was so cheap that noone would screw around welding a shagged one back together https://www.amayama.com/en/part/toyota/4882035030
  12. What was the problem with trailers? Just people cutting plates to fit?
  13. I trust it was driving afterwards? What ended up being the verdict with the blowby?
