chris r
chris r last won the day on May 21 2020
chris r had the most liked content!
Gender
Male
Local Area
Auckland
chris r's Achievements
Committed (5/5)
11.8k
I've used a couple of m&h resonators and was quite disappointed with them tbh. Didn't take any of the rasp out of the exhaust note (honda) I've used one of these Xlerator Enforcer Glass pack along with a turbo flow from the same company on my wagon and am really happy with it's note
chris r replied to yoeddynz's topic in Project Discussion
Could you add another cable to the throttle body/somewhere so if you are above 50% throttle for example it opens the butterflies -
The shroud arrived, it'll need some trimming to suit but was cheap enough I pulled the manifold off and sat the turbo in place with the v band adaptor bolted on so I can start figuring out the manifold. I'd be a lot easier to fit the tubo without the air con compressor The downpipe is going to be fun and a lot of bends too, it'll probably will do a U-turn then sneak behind the manifold and down. @Raizer trimmed the Drain fitting and that now fits nicely (I'll need to clock the core to sort out the angles ) The sinco merge collector is quite nice, I might need to shorten it a little as its quite long and space is limited I've ordered some more steampipe short radius bends as I don't have enough. The Nissan genuine studs for the turbo are 40mm M8x1.25 and are $12 each, The Honda studs are 38mm M8x1.25 and are $2.50 each so I'll order a bunch of honda studs and hope the 2mm won't make that much difference
After seeing flash sort the ac in his van (that was the kick I needed to start refitting) and with the diy hoses I figured I'd give it a crack too. Ordered some fittings and a meter of hose Didn't end up needing anywhere close to a meter And sitting ready for crimping I'll probably end up running the wires through the loom in the guard for the ac compressor and pressure switch as I won't any any of the engine loom on the front. Thinking about it I'll run the boost control solenoid with it and tuck it out of the way in that area
Grabbed some M5 stainless stuff in my travels today Drilled and tapped the rest of the mounting holes and mounted the condenser In one of the previous test fits I'd marked out where it would probably hit the body Took a brave pill and took the hacksaw to the offending piece and it clears And it's in position and (nearly) everything clears It's close to the bonnet latch so I might need to give it a trim but will see how it goes I was thinking I might need to make up some ducting but the drivers side doesn't have too many places for the air to escape through Passengers side is a different story but I'll deal with that one turbo manifold and plumbing is done
I found some aluminium strap in the scrap bin at work. Drilled and tapped it and mounted it to the rad. I've put some nylocs on the back to be extra safe @Raizer machined me up some spacers and I dummied up the condenser onto the rad. Will get some more screws etc at some point and finish mounting it I was dumb and was looking for a replacement fan as the one I had was in a pusher config. Actually had a look at the fan today and realised I could flip the blade and make it a puller config... Flipped the blade around and that's sorted. Also scored a shroud off trademe for a good price, It will need a bit of trimming
Here's some info to help id the cams https://www.ff-squad.com/tech/temp/VtecCams.htm B16a and type r cams go good in the B20s It'll go way harder if you can get it tuned, some accords (and us market integras) have a separate auto trans computer so you can get a tunable ecu (chipped if you want to call it that)
Redone the high pressure hardline to the receiver drier. Few more joins that I'd initially hoped for but they brazed up much nicer than the block did Cut some bends out of the selection of hardline I had. Needed to drill one out to suit the hose Lined everything up Brazed each section individually so only one thing would move I decided it'd be better to have a flexible hose both in and out of the condenser, less risk of my brazing fatiguing and cracking. Drilled out the compressor adaptor fitting to suit the hardline and brazed it on I'll make a little plate and bolt the fitting so it's secured
I was poking around looking for bulkhead connectors and found a deutsch connector which looked nice and worked with the crimper I already own. Little bit more poking around on the Te connectivity website and saw a sample button next to a version of the connector, but more poking around and there were more products with a sample button. Apparently it is not too good to be true and everything arrived. Now comes the part where I hope my spreadsheet and counting was correct and I do actually have enough pins to do what I want
The later model commodore electronic distributors fit in nicely put one into my tonner, only issue is the vac advance mechanism on mine isn't advancing so if your points dizzy is in good condition I'd leave it imo. And barries want way too much money for them All the old barries say headers and exhausts / electronic dizzy makes them quicker but the tonner did exactly the same 1/4 mile after headers /exhaust/electronic dizzy so it's probably just barry crap. Edit: if you change the timing gears may as well do the cam while you are in there... https://www.aucklandcams.co.nz/camlist/holden-149-202/
how you/brother/dad/uncle/cousin/mate used to have one Had had a nice hq wagon then wrote it off on the motorway - why my mrs is now tougher and cooler than me Your both a catch xo - why big Australian cars with a mix of metric and imperial fasteners are better than silly little European ones that only use metric ( i had to dig out my very limited and mismatched Imperial sockets and wrenches that had been banished to the back of bottom draw of the tool box and put them right in the top bit ) Adjustable spanner doesn't care about metric or imperial - where to get new parts easily/cheaply/locally Ebay has been pretty good for stuff if you are patient - why the second hand stuff on FBMP is outrageously priced and clearly owned by meth head bogans and how to avoid them - tips and tricks for hotting up your 173 using OEM + parts (commie inlet and exhaust manifolds? - the single stromberg and right angled log exhaust manifold offends me!)) Nah m8 get a set of flows and str8frew exhaust and it'll go like a cut cat that's had three of its legs cut off - can you bolt a 202 to the Torana 4 speed? Probably - where to find a nice 202. - why do i even want a 202 (re-rego mainly), the 173 is probably perfectly fine, KPie doesnt really care (unless its a v8), and it wont be the engine from the Torana any more, They are all bags of hammers - where the fuck is the fill port for the CNG system on this car? (its not behind the number plate with the petrol filler)
I went on a barry rabbit hole and found out pretty much all 92-2001 small hondas (b and d series motors) all have the same ac compressor. I noticed the orthia has a nicer shaped discharge (heh) hose, the crv has the same shaped hose so I grabed one from pick a part. It brings the line closer to the chassis rail and away from potential turbo stuff. Found a service port adapter and valve removal tool on rock auto for cheap so got them with some other stuff I had coming. Now low side has a R134 service port, it took me a few attempts to realise I needed to remove the old valve before screwing that fitting on I also grabbed a high pressure line off a ba Falcon so I can use the service port off that or just use the line as sleeve. I also figured out the self install or diy ac line kits use oetiker or double ear clamps on their lines. Once the condenser arrives I plan to chop the crv condenser end off and use the ear clamps on one of the fittings I got off AliExpress. If it doesn't work it was a $30 experiment and I can still use the crv alloy shaped hose and braze a mior fitting onto it
