Ryan's TE71 drift hack
  • Please log in to reply
5 replies to this topic
#1 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 10 July 2012 - 11:49 AM
Discussion - viewtopic.php?f=18&t=34803&view=unread#unread
Alright so this is the new project
The plan with this one is to spend as little as possible on the body and turn it into a bit of a drift missile.
The body is a early TE71 sprinter-trueno coupe that i picked up for a nice sum of $250 off ae25/mark
(excuse the shit phone pics)
Posted Image
Posted Image
Shes real rusty but solid where is counts
I brought a blacktop 4age from a wrecker but when it turned up and i started pulling it apart for the new timing belt, waterpump etc. Ive found its a silvertop bottom end with a blacktop top which is a nice surprise
Posted Image
The gearbox wil just be a standard T50 with a yet to be decided clutch
Posted Image
Suspension wise, ive brought Brendon Dunkers custom D2s out of his green machine and put on some AE86 slotted discs (ive forgotten the brand name but it starts with Z) and project MU pads
The rear suspension will be using a coilover shock system and ill just strengthen the pin on the diff housing. Im not going to bother with strengthening the top
Posted Image
A few skid tyres i picked up cheap
Posted Image
And my Techno TRVs that im going to get widened
Posted Image
Diff wise ive got a TA22 T series drum that im just going to lock and EURO8/Chris is building me a hydro handbrake.
#2 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 18 July 2012 - 10:56 PM
Nothing overly exciting
Got all the new cam seals, crank seal, water pump and cam belt on
Posted Image
Also brought an ae85 crossmember that ended up being purple with glitter once Chris/EURO8 got his hands on it! Quite stoked with that
Posted Image
Apart from that, the car is up in the air ready for parts to be swapped in but motivation is low with the garage being so cold at night so we will see how long that takes to happen
#3 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 30 July 2012 - 11:07 PM
Tiny bit done tonight
All the box steering gear is out including the column so i can convert it to rack and pinion using NZ new ke70 stuff. All the lower arms, steering arms and crossmember are with Todd so he can work his magic ;)
Posted Image
Also have purchased a few things
Posted Image
Posted Image
Doesn't seem like a lot but ive also been clearing room in the garage to make it a bit easier to work on. Now that that's done, updates should be coming a bit more regularly
#4 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 20 August 2012 - 10:44 PM
Update time
Finally managed to collect all the little bits for the ke70 rack conversion and after a bit of cutting and drilling, shes in
Posted Image
Also got 1 side of all the suspension in. Turns out this shell has the early bolt pattern for the camber plates so i needed to drill a few holes and do a bit of grinding for the custom camber plates
Posted Image
brought a set of extractors for Nicts car. I/Chris will play around with these just to make them a little different
Posted Image
Also Chris/EURON8 has added some gussets to my diff housing so that should support my rear coilovers. I just need to give the arms a lick of paint, push in the new bushes and put the diff in
Once its rolling, ill do the few last bits on the engine and then i can pop it in for the first time and see what needs to be fucked with
#5 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 09 September 2012 - 06:09 PM
So after a bit of fucking around with different inner tie rods, the front was done (excuse the lack of "tidy" in the next few pictures. Its only together for mocking up)
Posted Image
With the front done, i moved onto the rear end.
Shes now got new Whiteline bushes in my Honey Badger arms, locked diff and JAW strengthened pins to support the coilover shocks (as previously mentioned)
Posted Image
And with that all done, it was time to slam it back on the ground
Posted Image
Its sitting hard on the bump stops in the rear so i need to trim them down but the front is tucking 14"s with 175/60s (the picture doesn't really show this) and has HUGE amounts of camber so that will need to be played with a bit so i can measure my new outer lips
Heres a picture showing Todds handy work
Posted Image
Now to look at dropping the engine in......
#6 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 16 September 2012 - 04:22 PM
Today with the help of EURON8/Chris Cross, we managed to get the engine sitting in there
Posted Image
Posted Image
Also the extractors are a perfect fit
Posted Image
Now i have a million little things to do like sorting out the wiring, water pipes, fuel lines etc. I feel a bit lost as to where to start.
On monday ill go get a bunch of steel and what not and start with the water lines and gearbox crossmember i think
Back to the garage i go
