so i ripped my old motor out (not that intresting so no pics) and went to put my new one in and the sump was fouling on the swaybar so i took the swaybar out and im going to get this one customized up or a new bigger one made.
mocked up my intercooler, looks like im running bonnet pins as theres no room for the latch to go so i brought some of these
http://www.trademe.c...n-528843462.htm
so i took the swaybar out and it dropped straight in!
bolted it all in nothing to exciting i found out that the auto gearbox x-member works with the w55 with no modification at all!! choice so bolted that all up then driveshaft needs to be lengthened quite abit! like 150mm unless anyone has a standerd manual cressida driveshaft they wanna sell? had a look at the wiring looks piss easy im just to cab with that shit, most of the plugs are the same between the cressida and the 1ggte so yeah should be choice but ill leave that to the person wiring it up to do that
also fixed up the front end bas i hit a rabbit going 120ish and it left a rather large dent in the front of my car
had to hack abit of metal out of the trans tunnel cause the shifter position was to far fowards
also made the auto gear stick surround into a manual one by flipping around the little middle peice! works mint!
and my shifter on, i also brought one of those drift spin handbrake knobs
also in the market for a nice small gearknob, its hard to find good looking ones theese days
