Cletus' Valiant ute/s
#1
Posted 23 June 2012 - 08:28 PM
#2
Posted 24 June 2012 - 08:30 AM
what motor are you going to use????
also, what size are the wheels on it??
my MS51 and the ongoing saga. discuss the saga.
my 1UZ RA28 of daily usage discuss the V8 celica.
my 1JZ RA23 celica of dusty storage. discuss the 1JZ celica.
#3
Posted 24 June 2012 - 10:33 AM
If you get bored, pull a rocker cover off, and see what the casting number on the heads is, and if it has the adjustable rockers or not.
I have met Bart and He AIN'T normal
'72 Datsun B110 sedan, supercharged A15.
'70 Datsun P510 sedan, CA18DET. (One day gonna fit a screw blower)
'70 VG Valiant 770 Regal, .030 over 318 V8. viewtopic.php?f=17&t=19365 Discuss viewtopic.php?f=18&t=19367
'73 VJ Valiant Charger 770, Motor undecided. http://oldschool.co....updatelessness/ Discuss http://oldschool.co....al-awesomeness/
'82 Datsun PB310 Stock as A12.
#4
Posted 24 June 2012 - 01:58 PM
#5
Posted 25 June 2012 - 07:40 PM
i like.
wheels are 14x6.5. dunno which ones ill use, got a set of standard non charger type ones as well. going to get some wided to heaps, ive got a set of eagers to go on it.
engine will get a spraycan reco, its only a 273, but it runs well, its got a holley 2 barrel and my brothers got a set of headers laying around so thats what it shall recieve.
#6
Posted 26 June 2012 - 02:20 PM
#7
Posted 26 June 2012 - 02:44 PM
#8
Posted 09 July 2012 - 07:24 PM
#9
Posted 30 July 2012 - 05:50 PM
#10
Posted 30 July 2012 - 05:59 PM
#11
Posted 30 July 2012 - 06:09 PM
got an edelbrock performer dual plane. might keep my eyes peeled for a vac sec carb as well- since its not a powerhouse i would like to get reasonable economy out of itWhat manor of 4bbl manifold you got for the poor old Girl Clint?
#12
Posted 30 July 2012 - 07:18 PM
I'm no expert, but I'd wager it'll use less gas that your other SBM.
#13
Posted 30 July 2012 - 08:02 PM
checked the block and head casting numbers, couldnt find any info with the block numbers but it is a `67 block, the head casting numbers say they are `68-`72 318 heads, no adjustable rockers. when i was looking for a manifold, there was a factory early 273 4 barrel manifold on the tard,i did some research and the early 273 engine had heads specific to that engine with manifold bolts/threads on a different angle to all the other LA engines.
#14
Posted 01 August 2012 - 10:11 PM
I think all the motors that found their way out here did.
If you can stretch your budget to include a new pair of head gaskets, then this is the thread for you- http://www.forabodie... ... p?t=167865
You can get some free horsies right there.
#15
Posted 17 August 2012 - 10:12 PM
hes a good sort and knows alllllll the train spotting facts about such things.
hit me up if you want his number.
#16
Posted 19 August 2012 - 08:33 PM
#17
Posted 19 August 2012 - 09:12 PM
#18
Posted 20 August 2012 - 09:23 AM
That rust in the front lower caps (end of sill) is common as,they all go there.Ther only val ive not seen rust there was my vg coupe.
Looks to be a good honest body for a ute,they tended to get a bit more abuse than the cars and wagons.
viewtopic.php?f=17&t=27629
#19
Posted 20 August 2012 - 06:35 PM
#20
Posted 22 August 2012 - 04:35 PM
