viewtopic.php?f=17&t=33822
Cheers
Nikolai's SR20DE Avenger
Started by
NikolaiM
, 16 Jun 2012 09:32 PM
2 replies to this topic
#1
Posted 16 June 2012 - 09:32 PM
#2
Posted 16 June 2012 - 10:16 PM
Nice build/project fella. A wee tip from modifying Avengers in my past is that you need to strengthen up the rear bottom trailing arm. That fantastic bit of engineering that the rear spring sits in has a lot of force on it when cornering hard and under acceleration. Its an easy fix, just weld a plate to the top part of it, transforming it from a open c section to a rigged square box. Then it will be strong as, making your car handle better and will not bend or flex. I bent heaps years ago and had trouble finding them then, can only guess they would be harder to get now.
#3
Posted 16 June 2012 - 10:43 PM
Hm, its a s13 sr20de engine aye?
I can tune the sr20det ecu, see no reason why the de one would be any harder to do. Can fault diagnose the afm and tps etc.
It will need a daughter board installed in the ecu, i can supply and fit and tune for 500.
