this is it
GC i brought it off even dropped it of to me from te puke. got it cheap as it would start but not run when warm. as soon as i turned the fuel tap on there was fuel pissing every where, took carb of and both little tin floats had holes in them so the float bowl was never shutting. bit of solder later and problem solved. cleaned the black as spark plug up and away it went.
the only interesting thing so far is to get 8hp out of a side valve means its 298cc!! and huge. so just as well i got some pretty thick walled tube of Chris (thanks man) to build a frame. i am also going to make it direct drive due to lack of pull start as it is was broken and thrown out prier to me getting the engine and run starting is now mandatory. though i will likely steal petes idea of hand brake tensioner so i have some means of dis engaging drive.
hope to build some kind of a frame this week.
