chrom trim removal
  • Please log in to reply
8 replies to this topic
#1 craw
craw
    Member
  • Members
  • PipPip
  • 19 posts
Posted 05 May 2012 - 10:14 AM
Hi all i have a 1986 mk2 cortina that im in the prosess of stripping so i can panel and paint it
what is the best way to remove the chrom trim around the door tops and roof sills is the a special tool or am i better to leave them on and mask them off
thanks people
#2 Sorensin
Sorensin
    Post Fiend
  • Members
  • 699 posts
Posted 05 May 2012 - 10:25 AM
they should remove easily enough, from memory the bottom has a smaller lip than the top so lift from the bottom around the gutter, a flat screw driver is al you need, start lifting the bottom lip off from the body from one end once it starts coming off dont pull it at all just keep easing the bottom lip off all the way - this applies to the roof/ gutters
How are the door top chromes attached? might be clips? can be pushed from inside of the door?
#3 craw
craw
    Member
  • Members
  • PipPip
  • 19 posts
Posted 05 May 2012 - 10:30 AM
thanks for that they are attached in the same way sort of
#4 Sorensin
Sorensin
    Post Fiend
  • Members
  • 699 posts
Posted 05 May 2012 - 10:38 AM
cool, good luck- loved mk2s
#5 craw
craw
    Member
  • Members
  • PipPip
  • 19 posts
Posted 05 May 2012 - 10:44 AM
thanks will have to post some pics one day
#6 felixx
felixx
  • Members
  • 3507 posts
Posted 05 May 2012 - 06:56 PM
craw,
a) Post pics today
B) Where in NZ are you?
c) If in chch / canterburyish do you have a spare set of front shocks you want to sell
Between this polytech shit and the thing with the vag, I'm turning into such an antisocial mofo.
Please excuse my dumb questions. This is the first car I have worked on.
Felixx's Anglia Build Threadhttp://www.oldschool...hp?f=17&t=27168
Hurl Abuse at me about my Anglia http://www.oldschool...hp?f=18&t=27152
#7 craw
craw
    Member
  • Members
  • PipPip
  • 19 posts
Posted 07 May 2012 - 12:18 PM
Felixx
a) will when i get a chance
b)cambridge
c) sorry man need some myself and rears as well :(
#8 Beaver
Beaver
    Wellington Area Rep.
  • Area Reps
  • 6468 posts
  • Local Area:
    Wellington
Posted 07 May 2012 - 12:22 PM
the door trims are easy to damage so be very careful. do some hunting on the web, i remember seeing a how to for a mk2, and the dude used a small wooden wedge to pry them off.
the sill chrome is held on with little clip things so just use something to pry it away from the car and it will pop off.
#9 yeah yeah na
yeah yeah na
    Advanced Member
  • Members
  • PipPipPip
  • 64 posts
Posted 22 May 2012 - 07:57 PM
A block of wood and a small hammer, tap it lightly from under the gutter inside the door opening towards the outside,work along the length of it slowly or you will bend it.
