Can you drive with an empty power steering rack?
  • Please log in to reply
6 replies to this topic
#1 Lump
Lump
    Advanced Member
  • Members
  • PipPipPip
  • 114 posts
Posted 30 April 2012 - 06:42 PM
Long story short I've managed to bugger the pressure line fitting on my power steering rack (I went from a slight leak to a geyser) There's no chance of holding fluid in the system without refilling every few minutes.
If I disconnect the pump (which I'm guessing would burn out if a didn't) can I damage a power steering rack by driving for a short distance with no fluid in it (with a view to getting to someone who can fix it)?
#2 fulloc
fulloc
    Advanced Member
  • Members
  • PipPipPip
  • 460 posts
Posted 30 April 2012 - 06:53 PM
you can drive it.
i wouldnt drive far though...
take the belt off if possible and leave fluid in it to lube
#3 Maru-So
Maru-So
    Advanced Member
  • Members
  • PipPipPip
  • 114 posts
Posted 30 April 2012 - 07:40 PM
Power steering fluid has nothing to do with lubrication of rack so you're not going to damage it by driving around. I would take the belt off and empty the system before driving though.
#4 sholdowa
sholdowa
  • Members
  • 1563 posts
  • Local Area:
    Northland
Posted 01 May 2012 - 01:41 PM
yes, I've split a pipe on a long trip. Was a bit interesting seeing as every now and then I got a bit of a nudge from what little fluid was left, and there was 3 inches of snow on the roads.
#5 Lump
Lump
    Advanced Member
  • Members
  • PipPipPip
  • 114 posts
Posted 02 May 2012 - 11:10 PM
Shit that sounds a bit ropey
I've found someone who can have a look at it - so I'll disable the pump and give my forearms a workout for a change and get it sorted.
#6 Yowzer
Yowzer
    Waikato Area Rep.
  • Area Reps
  • 6755 posts
  • LocationHamilton
  • Local Area:
    Waikato
Posted 02 May 2012 - 11:16 PM
Depending on how the steering on the car is set up it can be pretty bloody hard work to steer as well.
My cressida had a lush fluid leak and when it ran dry it was quite the mission to turn corners.
Car
#7 hmmmnz
hmmmnz
    Advanced Member
  • Members
  • PipPipPip
  • 173 posts
Posted 03 May 2012 - 07:35 AM
yeah no drams,
i drove my old subaru leone for about a year with no power steering,
f knows how it kept passing warrants
...........merc camper.....................................vauxhall velox.......................... vespa (1)50.........
build.....................discussion     build..................................discussion.....build and discussion
