top tips for freeing up stuck pistons
#1
Posted 09 March 2012 - 11:35 AM
what are the best ways to free it up?
#2
Posted 09 March 2012 - 11:41 AM
smash the ceramic out of a spark plug and weld a grease nipple on it.
then pump some grease in there.
#3
Posted 09 March 2012 - 11:54 AM
if the heads off used the head bolts to bolt some angle or channel down with a hole in the middle with the big nut welded on and wind a bit bolt in to force piston down and free it up if you ar lucky.
Originally Posted by denmah
i dont wanna get caught up in stuff like this i just wanna hang turbos and do burnouts
#4
Posted 09 March 2012 - 12:11 PM
or warmed up diesel has never not worked for me
#5
Posted 09 March 2012 - 12:12 PM
Will most probably break the rings and it may have pitted the bore but nothing will turn back the hands of time (barring a Delorean)
N e v e r f o r g e t t h a t y o u r l a s t r i d e e v e r w i l l b e i n a s t a t i o n w a g o n .
#6
Posted 09 March 2012 - 12:17 PM
#7
Posted 09 March 2012 - 01:10 PM
Be cooking that shit in the microwave.
nothing like a warm glass of diesel before bed
#8
Posted 09 March 2012 - 01:17 PM
auto trans fuild + acetone is supposed to make boss penetrating oil never tried it though.
This shit is magic always have some mixed up, if you can get it MEK is better than Acetone, doesnt evaporate as quickly. A few cycles of heat and this shit has worked well for me
#9
Posted 09 March 2012 - 01:24 PM
ive heard the grease trick can crack heads and cylinders so that would be a very very last resort.
#12
Posted 09 March 2012 - 05:09 PM
fill with diesel, light on fire
grease would probably work, iv used it to pop various small pistons out (brakes)
top tip for removing a stuck head (but pistons move) stuff a rag down the sparkplug hole and crank over by hand
edit* I have also set up some blocks of wood and a hub puller to get a stuck piston out. Take care in setting this up as if you do it wrong you will break fins
talk about my worthless steel
Oh, i have something to haul parts with now
#13
Posted 09 March 2012 - 05:30 PM
how to fix old shit
#14
Posted 09 March 2012 - 10:08 PM
also setting the diesel on fire? that seems very simple, how effective is it? do you know how it works?
#15
Posted 09 March 2012 - 10:18 PM
#16
Posted 09 March 2012 - 10:22 PM
i think i saw it originally on the HAMB
but heres one i found just now
http://www.smokstak....ead.php?t=37566
#17
Posted 09 March 2012 - 10:39 PM
#18
Posted 09 March 2012 - 10:49 PM
Between this polytech shit and the thing with the vag, I'm turning into such an antisocial mofo.
Please excuse my dumb questions. This is the first car I have worked on.
Felixx's Anglia Build Threadhttp://www.oldschool...hp?f=17&t=27168
Hurl Abuse at me about my Anglia http://www.oldschool...hp?f=18&t=27152
#19
Posted 09 March 2012 - 10:52 PM
potential series? 'how to swear at and light old shit on fire, expecting miracles'
#20
Posted 09 March 2012 - 10:54 PM
with a bonus episode by Joan of Arc?actually, not a bad idea. will do,
