had these kicking around, makes it look even slower. May adjust them to look angry
Latest issues
horrible noise coming from the fan belt. Fanbelt is new, found it to be a wee water leak dripping onto the pulley, tightened the hose clamp and gave the waterpump gland nut a quarter turn.
Carb is still dribbling, needs a going over. Found a new one/fully rebuilt one in the UK for about $180nz. Considering taking the hit on that just to have a known good spare, although just about anything could be made to fit.
Pancake airfilter is a terrible fit, i would like an oilbath filter to go back on. have a spare from my minor that would fit, but would like something a bit closer
List of stuff to do
Make new tappet cover cork gasket
Make new carb gaskets
Replace clutch oiler flex line - may as well do the inch of fuel line while im there. Have old grey and black flecked stuff to go in.
Adjust or repair passengers door so it locks (i feel its a case of something not being put back the right way, probably upside down. There is broken glass in the bottom of the door, so it probably happened when that was replaced)
Make a better drivers floor - The floor is wood, i think i can do a better job than what is there and use less pieces
Find something to act as a catch can for the intake petrol overflow (manifold has a drain at the lowest point, prevents flooding caused by excess pressure i guess). From factory it has a copper line draining down next to the passenger side wheel. I would rather catch this, if only to see if any is being spat out
Eliminate some rattles. The front numberplate is louder than the engine. Which is a pretty good rattle to care about as far as concerning rattles in old cars go
Nothing major really, i should really pop the sump off and change the oil, would be nice to add an external oil filter - i am pretty sure there are some points on the engine where the lines would just bolt in
http://oldschool.co....hp?f=18&t=28405
