be4vers 4G63/4G63T EX Lancer 1981
  • Please log in to reply
62 replies to this topic
#1 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 21 June 2011 - 12:53 AM
Discuss here
well i thought it would be a good time to make one of these threads since theres nothing good on tv.
here is where it started, found this wee gem at the local wreckers and subsequently brought the shit out of it!
nearly fell over when they said $200!!
Posted Image
must have been a write off..
Posted Image
Posted Image
cost almost the same amount to replace the guard and lights as it did to buy the whole car haha.
Got it revinned and registered and drove it round for a year or so then took it off the road and got stuck in to it!
Posted Image
Posted Image
think there was a wee oil leak..
Posted Image
Posted Image
Posted Image
Posted Image
cleaned up alright
Posted Image
brought a premade exhaust off an ex off trade me,3" and goes right up to the firewall
Posted Image
scored some cheap rims care of the wreckers again, might paint them black!
Posted Image
got an n/a rvr engine since thats as far as the funds would stretch at the time. seems in pretty good nik tho!
Posted Image
cut and shut the manifold
Posted Image
made this crazed thing for the water pump
Posted Image
this is what i done with the back water outlet, no the most space efficient but i'm gunna box the firewall anyway so there will be heaps of room
Posted Image
Posted Image
had mad issues trying to find a rwd 7 bolt flywheel for it tho, im told they exist but i got impatient and gave up looking and instead got a mate to chop the gearbox to suit the fwd flywheel, so i ended up with a evo 3 flywheel with an rvr clutch plate and cover.
as you can see this was a dam mission and i would not recommend doing it this way!
Posted Image
not only was it a shit to get the starter lined up properly but the clutch plate was hitting too, nothing an angle grinder couldn't fix tho :D
Posted Image
Posted Image
with that all sorted i could finally put it in the hole, but first i made another hole! just to make life a little easier down the track the dash was already out so wasn't too much of a biggie
Posted Image
Posted Image
now put the engine in!
i originally was using a sigma crossmember but after a trial fit with that i found it sits the engine back too far so tracked down a 1600 ex one and that was perfect!
Posted Image
Posted Image
fuel system. over kill for this engine i know but it should be a turbo some time!
Posted Image
relined the boot and picked up some mint plastic mouldings
Posted Image
recovered the door cards, and other bits n pieces, looks way better than poo brown!
Posted Image
Posted Image
Posted Image
Posted Image
http://img535.imageshack.us/img535/8769/dsc01714os.jpg
http://img851.imageshack.us/img851/2042/dsc01854m.jpg
now to start on making it run!
http://img703.imageshack.us/img703/1703/dsc01862bw.jpg
http://img580.imageshack.us/img580/2596/dsc01864vp.jpg
http://img835.imageshack.us/img835/8998/dsc01866b.jpg
Found this lurking on trademe and snapped it up!
http://img35.imageshack.us/img35/4981/dsc01868h.jpg
been sitting for two years and wouldn't go.. had a seized fuel pump and stale fuel, so drained that shit out, got a pump and boom it started right up, sounds mint, no noisy tappets, clean oil and drives sweet! score!
only cost $600 aswell!!!!!
so now this will hopefully find its way into my ex in the not too distant future! so stay tuned!
http://img146.imageshack.us/img146/1716/dsc01878r.jpg
#2 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 21 June 2011 - 11:19 PM
had the day off work today so spend most of the day at the engineers getting bits n pieces done.
proper bracket for water pump thingo, this cunt ain't goin nowhere!
Posted Image
got all the water pipes and crap done too. has like a million joins but they seem to be holding up so far...
Posted Image
Posted Image
Also got the exhaust joined up to the extractors and all mounted proper, must say it sounds f ing mint. but way too loud, deff wont be getting a WOF like that!
Posted Image
#3 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 26 June 2011 - 12:25 PM
got the car down to the painters yesterday, done a shit ton more sanding and prep work. got the bog work redone since i pretty much made an abortion of it when i tried to do it. should just stick to my own trade lol.
Posted Image
Posted Image
Posted Image
ended up getting just one guard primed but should have the whole car done by the end of next week.
some dickhole thought it be a good idea to glue the light gasket thing in with some super hard no more nails type shit
Posted Image
got some wrx seats off trademe! $53 for the pair! they are a bit rough and one smells of cat piss but they were quite easy to modify to fit the ex. probly gunna get them recovered at some point.
Posted Image
Posted Image
#4 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 03 July 2011 - 07:04 PM
so i pretty much hate the shit out of sanding now but i think im finally finished
Posted Image
Posted Image
as you can see it got increasingly tedious as the day went on and on and on
Posted Image
Posted Image
Posted Image
Posted Image
after searching for months for some plugs to fit the 1600 dash cluster i got i gave up and just "customized" some plugs i found in an old mirage. it was pretty much the same and the couple contacts that didnt line up werent even used on the lancer dash.
Posted Image
Posted Image
just had to trim the lock tab a wee bit and swap a couple pins around
Posted Image
#5 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 10 July 2011 - 10:17 PM
ok get ready for a lame update!
here is my paint
Posted Image
here is changing my speedos over from the 1200 - 1600 dash just to keep the km the same
Posted Image
this OS build brought to you unofficially by monster energy!
Posted Image
#6 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 15 July 2011 - 09:24 PM
Posted Image
straight as fuck!!
Posted Image
looks funny with no windows, almost can tell what way forwards is lol
Posted Image
this was my first car, my inspiration so to speak haha, sold it to the wreckers for $100 back in the day :(
#7 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 18 July 2011 - 10:21 PM
saw this in the rvr and thought it might make a sweet gauge pod. a lick of paint and i rekin it looks pretty good.
Posted Image
Posted Image
Heres some shitcunt news... theres f ing rust in the pillar!dont know how i never noticed. someones had a go at bogging it up at some point.
Its such a small amount but it needs fixing and that means taking the window out god dammit!
Posted Image
Posted Image
#8 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 24 July 2011 - 10:02 PM
got the windscreen out in one piece! ...after a few swear words.
Posted Image
got a nice wee intercooler the other day too fits alright, will need some tricky piping made up as its a touch wider than i would have liked but it was cheap so i guess thats what ya get
Posted Image
#9 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 09 August 2011 - 06:27 PM
some recent purchases for when i swap engines :D
Posted Image
Posted Image
Posted Image
cars sill not painted :(
#10 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 19 August 2011 - 09:48 PM
started ripping into the rvr these last few days, getting sick of taking up valuable driveway real estate.
also i got my ute stuck on the grass when it snowed and i had to get back to work somehow ha ha so i chucked the plates off the ex on it and did a dodgy wee drive to work in the snow in it.
Posted Image
got this the other day too woop woop!
Posted Image
Posted Image
that is all for now.
car may or may not be painted soon...
#11 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 23 August 2011 - 09:11 PM
took this dirty bitch of an engine out tonight, it was a right cunt too! didnt know much about these sorta 4wd gay machines but i spose i do now. managed to get it out with out removing the driveshafts too!
Posted Image
Posted Image
and to top it off, once i had the engine dangling above the car the crane decided it would jam up and wouldn't budge from where it was so i had to clear some room behind the dam car and just push it away from under it so i could put it on the engine stand
#12 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 28 August 2011 - 04:21 PM
got some sweet news!
tracked down an old factory turbo ex! so i'll soon hopefully have two, yes two, of the 10 bolt diffs, turbo drive shafts and a turbo gearbox!
and what ever else i decide i might want
#13 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 31 August 2011 - 07:32 PM
brought this today. sort of an impulse buy haha don't quite know what i'm gunna do with it yet tho!
any ideas???
Posted Image
Posted Image
Posted Image
Posted Image
#14 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 07 September 2011 - 09:07 PM
got some gauges and put them in this wee pod thing, not too sure about it yet. whats everyone think?
Posted Image
#15 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 24 September 2011 - 10:53 AM
not too much to report lately just been spending spending spending $$$$$ :roll:
its worth it tho! look at this, is it wrong to get a semi over some car parts?
Posted Image
Posted Image
Posted Image
heard of another complete turbo ex somewhere out on a farm too! just waiting to hear from a mate of a mate who may or may not want to part with it. fingers crossed they dont know what its worth/ its not full of rust
#16 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 23 October 2011 - 05:07 PM
still waiting for the car to be painted and there ain't much i can do till i get it back from the painter man.
tidied up the tappet cover
first we had this
Posted Image
sand blasted
Posted Image
pianted
Posted Image
shineyed up words!
Posted Image
#17 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 31 October 2011 - 06:43 PM
FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK FUCK
Posted Image
that is all
#18 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 02 November 2011 - 09:06 PM
rust gone! finally ready to be painted. so before too long it'll be late nights in the garage putting it back together. but i just know i'm gunna struggle since it was almost a year and a half ago i pulled it all apart. :bounce:
Posted Image
Posted Image
#19 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 26 November 2011 - 11:58 AM
thoughts? these came with the ae70 i just got.
back fits mint, will just need to roll guards.
front sticks out like fuck.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#20 be4ver
be4ver
    Post Fiend
  • Members
  • 598 posts
Posted 12 December 2011 - 09:06 PM
started the car up the other day after having been sitting for months and it burst into life after about 3 turns, stoaked! must have done something right!
oh and paint getting put on tomorrow!!!
so tonight and yesterday just had a scrub up on the bare metal that's been showing for the last few months and gave it a good blow down.
Posted Image
Posted Image
Posted Image
