So Im slightly bored this evening and decided to chuck up an update of what little progress has been made in the last few weeks. Ive had a rummage around over the body and the patches of rust that have decided to show themselves are in slightly inconvenient places... the roof. When i pulled the headlining out there were a few drops of water just casually chilling at the top of the drivers side A pillar... well as it would appear there is surface rust on the roof skin but only where the frame around the sides exists
Pictures to explain what Im on about
Drivers side A pillar, this bit is the worst
above the drivers door frame
passenger side top of A pillar
Ive been chewing over how to get to this, Im really NOT keen on cutting the roof off coz i would image it to be the mission of all missions to get back on all lined up straight
. Ive thought about trying to slide a sanding disc in the gap between the frame and roof skin and then chucking huge amounts of rust convertor/killer onto it afterwards but i dont know if it would be possible to get enough pressure applied to the roof to remove the rust as the sanding disc has to follow the curvature of the roof.
Ideas on this would be choice as.
this is whats under the dash (passenger side)
If you get really close to your screen you shall see a small patch of rust in the top left corner, just above the huge square hole that the wiring harness travels through. anyway this small patch is directly behind the inside of the box section thats under the fender, ( the outer fender bolts to the top of the box section) anyway that section is looking a wee bit iffy/soft/thin as shit and so has made it was onto the list to be cut out.
When i was gentally removing the dash
theres the heater units... well theres 3 of them... the blower on the left and the heater unit on the right... however theres another one in the middle, it has two copper hoses coming out of the back of it but some muppet in the past ( not me) cut them off at the firewall
which is just dandy. anyway can anyone tell me if its some kind of old fashioned air con? i know NOTHING about air con but if this car originally had it id be uber keen to put it back in..
heres some pics of what the middle unit looks like, theres a little control unit thingy ma jiggy on the bottom of it as shown in pics
next on the list is get the brake/ fuel lines out and remove the gas tank... then hit the rust repairs.
I really needa get along to a meet and introduce myself.
Evan
