Ok Shit its been ages, I have got through so much but these photos make it look like stuff all haha
OK stripped out the POR 15 because it sucks, recoated with epoxy primer, still have more to go but its a low priority maybe in the next few days. I want to bang some black 2k on the floor to but if I dont get there epoxy will be fine
Ok so kept doing all the rust, small patch in the corner of the rear guard
Ugly funny shaped patch in the rear tailgate jamb, pretty shitty design with no drains here. Once the window well in the rear quarter went it looks like 10cm of water had been sitting here until it rusted through
Same with the other side, patch was allot more simple
Had to cut out the whole lower rear quarter section
Half way through piecing it together, would have been nice to do this in one pice and swage it in but just needed it done and I need some better tools
Blocked this out on the expoxy quickly with 180 using dry guide coat, love that shit
Spot fixing a few bits with easysand, its just a super fine polyester filler
Smoothed out and put back into epoxy
The whole car is actually now in 4 coats of high build urethane primer and has been for about 4 weeks, wanted it to sit for awhile and do any shrinking. Almost ready to block this and prep the door jambs & rear of doors for paint. Doors will then be hung and get the outside ready for paint
New spray gun 1.3 & 1.4 tips Austuro brand, pretty much a high end copy of a Iwata LPH-400, almost bought the LPH (or w400) but was talked into this gun, not dissapointed yet, sprays primo.
Engine came out and the firewall got bare metalled and epoxy primered.
Let this cure and did the seams with sika, I then sprayed more epoxy and wet sprayed some industrial (cheap) 2K black over it
I had piles of parts sandblasted, gas tank, bumper brackets, millions of under bonnet bits etc. I got the guys at the blasting place to epoxy the parts so they could sit around for abit. I scuffed about half the parts with red scotch brite and hung them in the shed for paint, hit them with epoxy primer and wet coated more 2K black on them. This black cures super hard, its good shit $120 for 4 litres and it mixes up to 6 litres with the hardener
OK kind of catching up to where I am at now. Today I fixed abit of rust in one of the doors, cut out this double skinned section and cleaned it up with various grinder attachments. Welded in a patch panel to the outside skin, painted the inside of both and welded it back together
Bare metalled all the doors over the last week, paint stripper, wire wheel, nylon stripping disks & finally cleaned up with the DA and scotch brite. One door had a pretty epic dent, took the best part of a day to fix using mostly welded on studs and a little slide hammer.
Hung the doors in the shed and epoxy primered them, hit them wet at the same time with 2k urethane primer mixed up as high fill mode. 2 coats of epoxy & 3 of high build
Sitting in the spare room curing, will block sand and fill a few small blemeshes next week
So the body is getting pretty close, due to time constraints with bathurst coming up I may get someone else to paint it. It is just so time consuming setting up the shed for a propper paint job
When I pulled the engine I went about checking it over, sadly there was copper coloured flakes in the oil! So I fully stripped the engine to find every main had run to some degree. Looks like it had been re-shelled in the past with std sized bearings (ie no crank gind or align hone) 455 mains tend to not be in-line and round after 40 years, so seems the re-shell without straightening things up has caused the problem. I have dropped the block off at the best engine machinist I could find, no one has a align hone large enough in Brisbane so I have to get it align bored. Anyway the block just passed the sonic test (very close to .1" on the pin side on number 6) it has already been opened up to .03" over so we should get away with 0.04" over but the block is on its last over bore! Full host of new parts pistons, cam, bearings etc are all on the way from the USA, should be easily done in time
Dropped off the driveshaft to be rebuilt yesterday, need allot of work it has a few big hits in it. Will be getting new tube, rubber dampener & UJ's. Also dropped off the radiator to be flushed and tested.
Also have a epic list of misc parts I will be ordering very soon, new fasteners, weatherstriping, alt, new starter, disc brake conversion etc etc
Busy busy!
