DJZ's 280ZX of Zilla-ness
  • Please log in to reply
132 replies to this topic
#1 Damien!
Damien!
  • Members
  • 1237 posts
Posted 01 February 2011 - 11:38 AM
Bout time you started a thread on this.
You would have had quite a project thread if you had.
#2 ryanfels
ryanfels
    ...likes this!
  • Members
  • 4795 posts
  • Local Area:
    Auckland
Posted 01 February 2011 - 11:47 AM
needs less turbos and more trumpets
#3 J-Calico
J-Calico
    Post Fiend
  • Members
  • 862 posts
Posted 01 February 2011 - 02:10 PM
damn,
i whole-heartidly(?) thought the sigma was gonig to be involved... :-(
ha
But really this looks as though its going to get very interesting.
is '26 a 32 motor? going to do any refresh/maintainence on it?
#4 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 01 February 2011 - 04:15 PM
Needs 1 less turbo and no trumpets.
The motor has a knock, I bought it cheap. It's out of a R32, hopefully it won't be too rooted when I pull it apart, I've got an N1 oil pump for it and some ARP rod bolts. It will be getting new bearings but I don't really want to pull the head off or pull the pistons out, but we'll see what happens.
#5 10Speed
10Speed
  • Members
  • 2125 posts
  • Local Area:
    Auckland
Posted 04 February 2011 - 06:07 AM
a v6 would pretty much make one of those mid-engined wouldn't it?
#6 mikuni
mikuni
    Bradkuni
  • Members
  • 9737 posts
  • Local Area:
    Northland
Posted 04 February 2011 - 07:22 AM
So cool. Would be lol to retain the gearbox and front shafts, but yeah nah, don't do that.
Looking forward to this build. I would suggest doing a little bit more of a bottom end rebuild if it actually has a knock, because if its not a major yet, it probably will be if you just throw bearings at it then go back to boosting.
#7 k-trips
k-trips
    Big Daddy Don Garlits
  • Administrators
  • 18120 posts
  • LocationWellington
  • Local Area:
    Wellington
Posted 04 February 2011 - 07:56 AM
Whatsthis?? You have a 320hp L28?
What are you doing with that motor??
#8 kyteler
kyteler
    Old Man Southern
  • Moderators
  • 16088 posts
  • Local Area:
    Southland
Posted 04 February 2011 - 08:04 AM
L28ET. DJZ is the man, refer to his avatar for further clarification.
#9 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 04 February 2011 - 09:18 AM
Yeah, the bottom end will be getting a bit more of a work over, the crank will need to be ground and the rod more than likely replaced, so I will probably just end up with another crank so I can stay with standard size bearings.
I'm investigating forged pistons and H/I beam rods but that's going to add $$ to the build.
L28 ended up getting split up which is a bit sad, I sold the bottom end and throttle bodies. I'll keep the head for the moment.
A VQ30 would end up pretty much inline with the strut towers, they are pretty awesome motors, my mate has a nearly standard one with a GT3540 that makes 430whp, it's going back for tuning in 2 weeks and will probably end up with 500+
#10 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 04 February 2011 - 09:19 AM
Oh and this was the L28 when it was running 278whp.
#11 Damien!
Damien!
  • Members
  • 1237 posts
Posted 04 February 2011 - 09:28 AM
^^^ Zak-attack
Are cranks easily accessible? Pricey?
#12 k-trips
k-trips
  • Administrators
  • 18120 posts
  • Local Area:
    Wellington
Posted 04 February 2011 - 10:34 AM
Surely you can regrind it cheap enough - oversize bearing shells FTW!!
#13 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 04 February 2011 - 11:04 AM
Decreased surface area FTL
#14 k-trips
k-trips
  • Administrators
  • 18120 posts
  • Local Area:
    Wellington
Posted 04 February 2011 - 01:40 PM
Not necessary FTL cos there is less drag - well at least thats why circle track guys use small journal cranks..
Could also offset grind the journal and achieve a slightly longer stroke
#15 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 04 February 2011 - 02:12 PM
Yeah I don't think it's such a good idea doing it especially when RBs have a well known history of oil supply problems, anyway the crank will more than likely just be replaced with a standard one, looks like I can one for less than getting the rooted crank ground.
Looks like I've found some 2nd hand JE forged pistons and some Tomei Poncams for $1200.
#16 ProZac
ProZac
  • Members
  • 1048 posts
Posted 05 February 2011 - 09:24 AM
*cough* VQ *cough*
#17 Damien!
Damien!
  • Members
  • 1237 posts
Posted 05 February 2011 - 04:26 PM
What HP figure will you be happy with?
Anything that'l beat Briceface?
#18 DJZ
DJZ
    Post Fiend
  • Members
  • 705 posts
Posted 05 February 2011 - 05:58 PM
Well I'll be spending more on fixing the motor than I would like so will probably have to stick with the twins for a while, I've heard they are good for 400hp but I'd be happy with as much as the L series was making for the moment.
#19 Brock-Lee
Brock-Lee
    Moderator
  • Moderators
  • 5337 posts
  • LocationWellingtonne
  • Local Area:
    Wellington
Posted 05 February 2011 - 06:04 PM
Mate was making 420whp @ ~20psi with stock twins out of an r33 motor. That was really starting to just blow hot air at those numbers
#20 Damien!
Damien!
  • Members
  • 1237 posts
Posted 05 February 2011 - 07:11 PM
Oh yeah, I did see the silicon everywhere.
Forgot to mention that.
