Truenotch's 1981 910 Wag (A rich patchwork tapestry)
  • Please log in to reply
14 replies to this topic
#1 Hemi
Hemi
    Smashing 2 Doz
  • Members
  • 4467 posts
Posted 14 October 2010 - 07:24 PM
Discuss: viewtopic.php?f=18&t=24493
soo been looking for a wagon for a while now. so after a severly chop riddled night with kk dadums E and co i woke up early and massivly hung to catch a flight to aucks to view/ buy this
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
after a detour with rot808 and euron8 i was the owner ! , drove it to whakatane to pick up some doors etc, then back to welly , minor miss here and there but other then that went amazingly well!! .
unfortunatly my camera died so no update pics buuut i started cleaning up small bubbles around the areas that would stop a wof . i then decided to test the waters of the primered corners on the a and d pillars ... omg ! long story short polyester filler was swapped for steel bad part is i suck sooo bad and finishing so it looks rough as shit . dont care its better then bog being my rollcage .
also did mechanical check and im happy as with it . replced the two lower control arm balljoints due to ripped boots and minor play in l.h one .
oh and how could i forget whle putting the l.h d pillar window in it exploded showering me , the car and the next couple bays in glass . dropped my tools and walked 10 k home .
BUT thanks the DIRTY LEPPER i got another window today !! thanks man you my friend are a grade A legend!! .
other then that i have given the inside a good tidy up and went over all the windows with a blade , scrub window clean and on the front some sweet rain repelllent .
yes i know updates without pics blow gulf water but my camera stopped working ! :evil:
plans after wof check are slam , cb , roofracks . transfer doof doof from hardtop to this and in a bit tints or curtains for rear
#2 Hemi
Hemi
    Smashing 2 Doz
  • Members
  • 4467 posts
Posted 15 October 2010 - 05:56 PM
pics you say?? . ok!
Posted Image
here are some of my shit looking repairs (i have no patience for finishing)
a pillars.
Posted Image
Posted Image
d pillar work
Posted Image
last bit of corrosion gone within the structure welded filled and spray puttied
Posted Image
sweet colour scheme , this is not factory the brown is vinyl spray , i reckon it looks neat as shit
Posted Image
wagon whaaat
Posted Image
my little grill upgrade , got a silver 50th anniversary nissan badge for it too thanks to mr seedies 910 sedan i parted out .
Posted Image
sweet steels with stainless beauty rings and BLURBIRD hubcaps!!!
Posted Image
oh hai side pic .. hrmm whats that over there?
Posted Image
Posted Image
yay for roofracks!
Posted Image
and a bit off topic but hello
Posted Image
Posted Image
#3 Hemi
Hemi
    Smashing 2 Doz
  • Members
  • 4467 posts
Posted 16 October 2010 - 02:54 PM
more pics , trial fitted fins with 185 55 14's on them , as you can see the wheels stick in front and not enough in rear , but slam will tell.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
#4 Hemi
Hemi
    Smashing 2 Doz
  • Members
  • 4467 posts
Posted 18 October 2010 - 06:13 PM
soo today was judgement day , took wagon down to my usual place for wofs . came back with two items . numberplate light and muffler rubber mount missing ... fuck yes!!!! .
so will have warrent tomorrow then its the sounds from hardtop into it , adressing the ride hieght , and i was thinking about these but by the look they require tremendous amount of holes in the roof , which is somthing im not happy with at all
Posted Image
Posted Image
Posted Imageso umming and arring about that .
prob cant afford a cb this week. i will try though , hopefully nate can sort me a sweet deal asap . must hit him up
#5 Hemi
Hemi
    Smashing 2 Doz
  • Members
  • 4467 posts
Posted 01 November 2010 - 04:35 PM
so fitted a cb in the end thanks to a good mate at work , even suits the era!! yay!
Posted Image
Posted Image
worked a treat too , sooo dont regret getting one of those at all!!!
anyway lowering so decided to make blocks because im tight and such
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
adn fitted to the rear
Posted Image
Posted Image
Posted Image
i then tried to fit the coilovers to the front but the steels told me to fuck off .
So im going to get tyres on the fins and fit them , this leaves me with another problem though , the shock nounts will be about 50mm off the ground . not keen. sooo looks like i might be reseting the leaves . anyone know how much this usually costs ?
there was somthing else too . oh yea i want an ld28+t . but that can wait till the hardtop gets its new motor as im taking up a wee bit too much room in the workshop
#6 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 08 May 2011 - 04:50 PM
Those of you who were at nats will know I bought this from hemi. Needs more rust work for a WOF, but here's hoping.
Looks like this at the mo
Posted Image
Posted Image
#7 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 23 May 2011 - 04:54 PM
New water pump fitted - the old one had about 10mm of play in the bearing and began to sound like the rapture (which didn't happen).
Also tightened up the tappet clearances to remove the daylight that was trapped between the cam and rocker arms. It's as quiet as a viscous fan now!
Put a timing light on and lolled that it still had 25' advance even after cranking it back by miles. Now running 12-14' advance. NO PINKING, smooth as a new one and pulls it to 100K nicely.
Quite chuffed with the fuel economy as well. I just finished off the OS nats tank - 560k's on 50 or so litres of fuel! Not bad for an old donk.
Next up: Unslam and weld patches for WOF
Possibly add supercharger
#8 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 03 August 2011 - 10:07 PM
Now for sale:
viewtopic.php?f=14&t=28582
#9 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 15 August 2011 - 07:41 PM
Posted Image
#10 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 28 August 2011 - 09:32 PM
Decided to keep this and have a go at the rust with the help of a panel beater friend.
It was worse than I expected.
D-pillar:
Posted Image
Bog, bog, paper, rust, hole, bog, paper - repeat.
Under rear bumper:
Posted Image
D-Pillar:
Posted Image
Windscreen:
Posted Image
We're going to crack into it over the next 3 weeks and should end up with a solid, non leaky, WOF spec wagon. The carpet needs to come out and dry off too and everything has a layer of moisture after the weather we've been having recently.
Then it shal be slammed again.
http://www.oldschool... ... 3&start=40
#11 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 10 September 2011 - 10:43 PM
Front
Posted Image
Posted Image
Rear to come.
#12 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 06 October 2011 - 10:47 PM
Damn straight it's made of steel (now).
Posted Image
viewtopic.php?f=18&t=24493&start=60
#13 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 08 October 2011 - 06:17 PM
Posted Image
Posted Image
Posted Image
Getting closer. Small piece to do on this D pillar then it's onto the doors and paint.
http://www.oldschool... ... 3&start=60
#14 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 02 November 2011 - 11:09 PM
Want back
Posted Image
It isn't too far off now. Patches have been filled, sanded and primed. Going to pull the doors off and fix the bottoms before fitting fender mirrors and going for paint (almost a full respray now).
Would seem a shame to trade it down to my little brother.
#15 Truenotch
Truenotch
    Moderator
  • Moderators
  • 5939 posts
  • Local Area:
    Waikato
Posted 11 December 2011 - 04:52 PM
I think this is getting out of hand...
Posted Image
Posted Image
Still need to do the doors. Patch priming is all done on the body and it will get a full respray in the new year.
