anhonyb's 72 HC viva
#1
Posted 13 December 2009 - 06:32 PM
I need some tips with my painting on my car can anyone help??
Project http://www.oldschool...hp?f=17&t=20530
Discussion http://www.oldschool...hp?f=18&t=21162
83' MK5 Cortina wag
Project http://oldschool.co....hp?f=17&t=27417
Discussion http://oldschool.co....hp?f=18&t=27418
#2
Posted 13 December 2009 - 06:46 PM
I've found in the past when i've painted stuff that if i get a rough surface i can usually coloursand/polish it up pretty good. try rubbing down a bit between coats and then put a couple of steady clearcoats on the top and cut them back with fine grade sandpaper then buff out. Any good to you? This worked very well with the metalflake i put on my daily, its was very bumpy with the flakes so i put loads of clear on and cut it back to smooth - i even polished it by hand and it still came out good
Any word on your bits yet?
1974 Vauxhall Magnum :
http://www.oldschool...hp?f=17&t=13876
http://oldschool.co....hp?f=18&t=13883
1970 Opel GT:
http://www.oldschool...=328588#p328588
http://www.oldschool...hp?f=18&t=14927
#3
Posted 13 December 2009 - 06:55 PM
and magnum bits=fail haha at this stage my recond 1800 is just going to be sitting here
83' MK5 Cortina wag
#4
Posted 13 December 2009 - 07:06 PM
#5
Posted 13 December 2009 - 07:13 PM
83' MK5 Cortina wag
#6
Posted 13 December 2009 - 07:14 PM
#7
Posted 13 December 2009 - 07:16 PM
83' MK5 Cortina wag
#8
Posted 13 December 2009 - 07:19 PM
if its just slightly satin looking like this
then its proably just a base coat and would need a clear coat on top
#9
Posted 13 December 2009 - 07:20 PM
just go a bit slower get the paint looking nice and wet when you spray it
#10
Posted 13 December 2009 - 07:23 PM
83' MK5 Cortina wag
#11
Posted 13 December 2009 - 07:27 PM
leave it outside in the sun a few times to speed it up
#12
Posted 13 December 2009 - 07:35 PM
83' MK5 Cortina wag
#13
Posted 13 December 2009 - 10:30 PM
same as the primer, give it plenty of time do cure before painting
#14
Posted 13 December 2009 - 10:48 PM
83' MK5 Cortina wag
#15
Posted 13 December 2009 - 11:49 PM
#16
Posted 13 December 2009 - 11:57 PM
83' MK5 Cortina wag
#17
Posted 14 December 2009 - 06:04 PM
83' MK5 Cortina wag
#18
Posted 14 December 2009 - 07:50 PM
#19
Posted 14 December 2009 - 07:54 PM
83' MK5 Cortina wag
#20
Posted 14 December 2009 - 08:04 PM
a 1L bottle should surfice
