Dodgysam's wifes 1980 Mini thou.
  • Please log in to reply
14 replies to this topic
#1 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 03 November 2009 - 10:16 PM
Hello all.
Just thought i'd post up some pics of the mini that im attempting to do up for the wife.
Its fun cos I havent really done any kind of resto before so I'm learning as i go along.
This was how she looked when I got her.
Posted Image
Looks good but there is a fair bit of work under that Ford blue paint.
Posted Image
Posted Image
Front flare test fitted and the disc brakes from a 2000 mini fitted. No more drums for this old girl!
Posted Image
Posted Image
Posted Image
I dont know if its very original but i shaved the boot. So there will only be the numberplate/recess and a lock.
Posted Image
Posted Image
Also I just tacked up the new high stop brake light.
Looks ok considering it still has the weld burns and is just tacked in place so not finished off in this pic.
Posted Image
And the reason its there is cos it is the wifes car and shes a dodgy driver at the best of times and i figured this was better than just sticking one in the already tiny back window.
Also i mounted up a new aerial and welded up the old hole.
Posted Image
Posted Image
Posted Image
Got the front windscreen out and that also shows the crx seats all fitted and mounted.
The drivers seat has been rebolstered so fits like a race seat.
Posted Image
The brake light and aerial. The brakelight is moulded in so it doesnt look so huckery. Still needs some finishing sanding but you get the idea. And the aerial is all wired in and ready to be powered up.
Posted Image
I found quite a bit of rust around the fuel filler spout so i removed the tank and cut out the rust. I completely welded over the fuel filler hole, filled it and then redrilled the hole so it looks all fresh and new.
Posted Image
Posted Image
And lastly i moulded in the drivers side rear wheel arch. Looks a bit tidier than just riveting it to the panel.
Posted Image
I filled the indicator recess and moulded in the front wheel arch.
Posted Image
As you can see i had a wee bit of a gap between the arch and the bodywork...so i glassed it up.
Posted Image
This is the drivers side arch after it was glassed and filled and primed.
The parcel tray behind the rear seat is like swiss cheese so instead of trying to fix it I've just cut the whole thing out and am making up a whole new one from a sheet of steel.
Thats about as far as i can go on the body work till it gets sent off to the panelbeater on Monday to weld up the major rust holes for certification.
Once its back i will post up some more pics as i keep going with things.
Sam.
#2 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 04 November 2009 - 11:44 AM
OK...this is just some of the rust that is about to be fixed.
Under the petrol tank...
Posted Image
Drivers side of the boot...
Posted Image
The missing parcel shelf...
Posted Image
One of the rust holes in the passenger side front wheel arch, its right next to the door hinges so this is why im not too happy to do it myself.
Posted Image
And this is the new stromberg carb thats gonna get fitted once it gets rejetted and given a good service.
Posted Image
#3 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 06 December 2009 - 05:14 PM
So I stopped playing with my trike long enough to do some work on the mini this weekend.
I have been hunting for months now for the perfect exhaust tip but couldnt find what I wanted...so stuffit...I'll make it myself.
Posted Image
Posted Image
So its a 45mm inlet and about a 5inch outlet which is about an inch high.
And of course its not a mini unless it has a centre exit exhaust so I figured this would look a wee bit different.
Also lets play a game.
Lets play "spot the numberplate lights"
Posted Image
So now apart from a paint the boot lid is all finished...YAY ME!!!!
#4 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 10 January 2010 - 07:29 PM
so I've been super lazy when it comes to the mini lately but this weekend between swims was a goodie!
Made a new rear parcel shelf from some sheet steel yesterday.
the shitty old rusted cut to shit one!
Posted Image
from this...
Posted Image
to this...
Posted Image
Posted Image
...and today took off the skin of the passenger door...
I tell ya its not too pretty inside them doors thats for sure, but it could've been a whole lot worse!
So tomorrow i will try to weld in some new metal to replace the rusted mess i cut out of the frame.
Posted Image
Its all a learning curve i tells ya but it was gonna cost me $1200 for a panelbeater to do the doors and i just dont wanna pay that!...(I guess thats the penny pinching Scotsman coming out in me).
And incase I didnt show Y'all earlier this is the zorst thats gonna go on the mini...a good old RC40 mini box with my home made tip...all attached to a straight pipe of course!
Posted Image
Also did some welding on a guys stepdaughters car yesterday...turns out he is an autosparky. So now hes gonna rewire the mini for me and sort out the earthing probs...sweet...more money i dont have to spend...YAY ME!
That is all!
#5 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 11 January 2010 - 04:45 PM
went to the manliest place on earth today...aka pick a part...and got some Jaguar xj6 rear seatbelts. Am replacing the static fixed rear belts for retractable ones...make things a bit tidier.
Will get pics up when they are all mounted n stuff.
That is all!
#6 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 11 January 2010 - 06:41 PM
here are the belts all mounted n stuff.
Just need to weld the retaining nuts in place.
Posted Image
Posted Image
I even managed to find a set of belts with the factory covers...just like my dads old Austin Allegro had when I was a kid!
Posted Image
I over engineered the mounting so it shouldnt have any probs come cert time.
Posted Image
Its just a retaining nut through the sheet steel from factory so I figured this would be a safer option for anyone who was unfortunate enough to be riding in the back seats.
Also it looks just a wee bit different from the average mini...which is what I was aiming for.
That is all!
#7 punkoutnz
punkoutnz
    Post Fiend
  • Members
  • 577 posts
  • LocationDorkland
  • Local Area:
    Northland
Posted 20 March 2011 - 05:53 PM
Sam have you STILL not finished this thing? Come on bro, I'll have a wife before you get this thing back on the road! :P
P.S = Hi all!
#8 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 20 March 2011 - 05:58 PM
shuttup Fluffy!
you want it finished come help me.
#9 punkoutnz
punkoutnz
    Post Fiend
  • Members
  • 577 posts
  • LocationDorkland
  • Local Area:
    Northland
Posted 20 March 2011 - 08:00 PM
You provide the beverages and the tools, I'll provide some labour. Hell we should get HEFTY going the same weekend... Lulz
#10 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 20 March 2011 - 08:05 PM
Hefty is never gonna go!
#11 punkoutnz
punkoutnz
    Post Fiend
  • Members
  • 577 posts
  • LocationDorkland
  • Local Area:
    Northland
Posted 17 April 2011 - 04:59 PM
Hey Sam, next weekend is a long weekend... Reckon we can finish Mavis by Monday?
#12 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 17 April 2011 - 06:01 PM
we could give it a go.Have a few things on but everything can be shuffled.
#13 punkoutnz
punkoutnz
    Post Fiend
  • Members
  • 577 posts
  • LocationDorkland
  • Local Area:
    Northland
Posted 17 April 2011 - 06:06 PM
Sweet! Should knuckle in and get one days work done at least.
#14 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 17 April 2011 - 06:07 PM
dood...dont post in here...you will get mod yelled at.
Post in here...
viewtopic.php?f=18&t=20704
#15 DodgySam
DodgySam
    Struggle Snuggler
  • Members
  • 3926 posts
Posted 06 October 2011 - 05:58 PM
So its a boring update...but its an update!
Stripped out the hardware in the doors today ready to swap into the new reco'd doors.
Thats the last bit of the body work to do on the minge.
Now all I gotta do is strip the roof and inside the cabin, remove the engine and strip that too.
Then its paint on!
